Question about Smartpond Refurbished 330 GPH Pond Pump
Smartpond impeller jams
I get it going and then a couple days later it jams again??!??! I doesn't seem to be dirty or broken though it never seems to turn real easy. Should I just buy a new one?
Water comes out but spray arms don't turn and motor doesn't seem to be runing
Sounds like a bad pump/motor. It is also possible that something hard (like broken glass) got down into the pump impeller, stopping it from turning. Depending on the brand and model, this may be easy or hard to check and clean out.
Sep 20, 2014 | Frigidaire Dishwashers
Vizio not getting power
The screeching noise might be to a damaged back-light inverter board. Your TV must checked. Contact any service technician. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 18, 2013 | Vizio L32 32 in. LCD HDTV
Victory pride 9 motor runs but doesn't drive wheels
Good day,it sounds as though the Motor Coupling could have broken up.I would say seek advice from a scooter repair person.If it is what I say,the job is not a big or costly 1.I say this as many repair people do not take on jobs,that you have tried fixing.I hope my advice was good,have a nice day.Colin
Mar 07, 2013 | Health & Beauty
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
1) The lever at the back that keeps the foot up when threading etc will not stay up on it's own. When you put it up, it just falls bak down a second later. 2) The needle won't go up and down,...
it sounds like the take up lever has either come loose or is broken, & since the needle won't go up & down it needs to be checked
Aug 02, 2011 | Singer 1507
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
Robokleen stays in same spot going back and forth about four feet wont go around pool it was stuck the other day on a pool toy and couldnt get off of it we didnt know about it til we pulled it out later...
With these automatic pool cleaners, a jammed impeller can cause it to not work. Since the cleaner was caught on a pool toy, my guess is that it has some fabric/material jammed in the impeller and that is causing your problems. Open it up and check your impeller. I am sure that you will find it jammed.
Jul 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
Smartpond Refurbished 330 GPH Pond Pump Logo
Top Smartpond Plumbing Experts
Paul Carew
Tom Chichester
Are you a Smartpond Plumbing Expert? Answer questions, earn points and help others
