Question about LG 32LG30 32 in. LCD HDTV
Pushed a button and no sound
Accidentally pushed a button no sound there is yellow message box on screen
    Top Expert:
  • LG Master
  • 14,553 Answers
If it is what you say look in customer menu (if message box shows image of a speaker with / across it you may have by accident switched the internal speakers off......
Posted on Oct 26, 2012
Reset intermec cn70
There are 3 ways to reset the device:
Warm Boot - When an application becomes unresponsive.
Press the Yellow Power button (also referred to as the IO Button) and select the reboot option.
Cold Boot - When device itself becomes unresponsive, will loose any cached data.
Press the Yellow Power Button (also referred to as the IO Button) to suspend the device. Remove the battery pack and press the reset button in the battery compartment (Round rubber button). Replace the battery pack and press the yellow power button or IO button. The blue Intermec startup screen appears.
Clean Boot - When device itself becomes unresponsive and cold boot fails, device will be restored to factory state, all data and installed applications will be lost except for data stored in Flash Storage.
- Firmware 1.50.19.0013 and prior -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) and volume down button (the lower
button on the right side) together until a message box appears on the screen stating the clean boot. Press the volume up button (the upper button on the right side) to confirm the clean boot.
- Firmware 1.62.27.6 and later -
Remove the battery pack and press the reset button in the battery compartment. Replace the battery pack and immediately press the yellow power button (IO button) for 8 seconds. Message box will appear stating to release the power button. Press button number 1 then button number 2, confirm again by pressing button number 1 then number 2 again. Message box will state that the device is clean booting.
Jun 20, 2014 | Intermec CN70 Handheld Mobile Computer...
When I push '-' to make image smaller screen goes black
Check your setting in "Custom Functions". Sounds like your "-" (or more specifically your "*" button) has had a feature enabled. I had my "*" button set for focusing - under Focus Settings in Customs Functions. If in doubt reset all Custom Functions to their default.
Mar 05, 2014 | Canon EOS 40D Digital Camera
Lost signal
Have you tried to push the tv input button? Sometimes when a button is buy accident it changes the input on the tv. Hope this works, let me know.
Good luck, Toni
Nov 29, 2011 | Televison & Video
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
Do you have virgin codes for eurovox
you need to reset box and then re insert codes from before
Jun 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Stability System Reset Button on a 2003 Cadilac CTS
YOU HAVE TO HOLD THE TRACTION CONTROL BUTTON IN THE GLOVE BOX DOWN FOR 7SEC. YOU'LL THEN SEE A MESSAGE SAYING THE STABILITY SYSTEM IS OFF. IF YOU ACCIDENTALLY LET GO BEFORE IT SAYS IT'S OFF, YOU HAVE TO PUSH THE BUTTON AGAIN, AND START OVER.
Jan 17, 2009 | 2003 Cadillac CTS
Curtis DVD 6500 Blank Screen
Sounds like you have accidentally gone into the scanning mode. Press and hold the subtitles button for 5 seconds to get out of this.
Apr 03, 2008 | Curtis Televison & Video
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
LG 32LG30 32 in. LCD HDTV Logo
21 people viewed this question
Computer Repairing
Computer Repairing
