Question about Samsung TSL3295HF TV
Samsung TSL2795 HF Color probs.
Sound has become erratic. Sometimes becomes pretty loud, sometimes have to turn up sound 3/4 to hear. Major problem with color which varies from normal to everything has red tint or green tint.
    Genius:
  • 1,847 Answers
There may be a purity alignment problem, or the mask in the CRT may be
defective or magnetized. The tech should first check to see if the
degaussing coil around the CRT is working properly. He can also try
using a manual degaussing coil to demagnetize the mask.
Posted on Jan 03, 2009
  • Legin Varghese
    Legin Varghese Jan 03, 2009
    The purity alignment is not something the end user can do himself.
    There are also some safety issues in doing this yourself, and you would
    require the proper training and setup to do this.
    If the CRT mask is defective the CRT will have to be replaced.
My Samsung T220HD was having problems turning on. The red light would flash once instead of 3 times, there would be an odd sound, and the screen would look a little weird. I would have to wait a few...
Many times the main circuit board becomes defective, especially after a power surge. If you had power fluctuations lately, the board could have become compromised. A shorted board needs replacement. Sometimes the cost of repair becomes greater than purchasing a new system.
Jan 14, 2018 | Samsung T220HD 22 in. LCD TV
Sound at 50-70 is not that loud. we have another model same size and samsung that is extremely loud at 25.. i dont understand
Speakers sometimes become damaged when going at high levels from low levels and just switching like that..... This may be the cause for it to be kind of low.... Best not to turn it all the way up or it might just blow the speaker fully..... You may have a a volume limit set on it.... Check that, it might be not allowing your speakers to play any louder.... Otherwise, it is best not to have your speakers blaring, just have them kind of low, and your ears will adjust.... People lose hearing when they have their TV's turned all the way up and all loud... Plus it just kind of disrupts the peace of a home :) Good Luck :D
Jan 08, 2011 | Samsung LN32C350 32 in. TV
The ignition of the oven is erratic. Some times it won't ignite. sometimes it dosen't ever reach temperature. sometimes it work as expected. Sometimes it will ignate if one of the(stove top) burners is...
NO LONGER NEED ASSISTANCE. FURTHER RESEARCH ON THE INTERNET DISCOVERED OTHER STOVE OWNERS WITH THE SAME PROBLEM. IGNITOR REPLACEMENT FIXED THEIR PROBLEM. I'VE ORDERED THE PARTS.
Jan 23, 2010 | Viking VGIC305-4B Gas Kitchen Range
Drum not turning-very loud sound coming frm dryer when turned on
There could be multiple problems with you whirlpool dyer depending on the type of noise you are hearing. If the noise is a low grumble or loud buzzing sound this could indicate a bad motor. Which could explain you not hearing the drum turning. If however you hear a grating or grinding type noise but the drum is turning, this could indicate that something is rubbing or has become jammed inside the blower fan that circulates the air. if this is the case it too may have to be replaced. Also the drum can sometime come off the drum support rollers at the back of the dryer, but this is very uncommon, and only happens if they are very worn or broken. This can easily be diagnosed by a technician and if the motor is fine, will cost little to repair.Hope this helps.
Thanks
Nov 07, 2009 | Whirlpool LER4634J Electric Dryer
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Sound problem
Try to check your dvd manual if one is available. turn to the sound section and try to check if your dvd is in the correct settings.
Feb 18, 2007 | Panasonic SC-HT1500 System
Samsung TSL3295HF TV Logo
41 people viewed this question
Jerry Greenberg
Jerry Greenberg
