Question about M&S Systems M & S SYSTEMS DMC1CDB Whole House CD Player for DMC1 CD Player
M & S master fuse location - M&S Systems M & S SYSTEMS DMC1CDB Whole House CD Player for DMC1 CD Player
    Master:
  • 444 Answers
Inside the unit.
Posted on Oct 28, 2012
What is required to replace a fuel pump relay in a 2003 Ford Explorer?
In the under hood fuse box, beside the master cylinder. The fuel pump relay location number is 50B, in the same box also check fuse # 23 which I believe is a 20 Amp Mini fuse for fuel pump power.
Feb 09, 2017 | 2003 Ford Explorer
Cant find fuse for power windows?
According with the Explorer Owner Guide, I suggest...
1. Check for power on the Light Blue/Black (LB/BK) wire at the master window switch.
2. Check for a good ground to the master window switch on the Black (BK) wire. This wire provides the ground circuit for all of the window motors.
If both of these are good you probably have a bad master switch(drivers master switch).
The Light Blue/Black (LB/BK) wire gets its power supply from the accessory delay relay in the Central Junction Box (CJB) located under the instrument panel. The Generic Electronic Module (GEM) controls activation of the accessory delay relay. Fuse 2.17 is a 15 amp fuse in the CJB which supplies power to the relay. Fuse F1.6 is a 60 amp fuse in Battery Junction Box (BJB) which also supplies power to the accessory delay relay. G400(ground) is located at the driver side rear of the vehicle near the tail light assembly. This connection provides a ground for the master window switch (click image for zoom).
For additional details, i suggest try to look and obtain this 2002 Explorer Owner Guide 6th Printing (English).
Hope helps.
Oct 12, 2011 | 2002 Ford Explorer
Just installed ignitor PP200 & Gma 10-R fuse, unit ran for approx 4 min & blew the fuse & burnt the ignitor up . Our parts available thru your location. Is their a troubleshooting guide...
It sounds as if you have a defective control board.
Find your exact model (example= B100T). Then, go to this page and find which board is in your particular model. Don't guess. http://www.reddyparts.com/master_heater_reference.htm
Then, go to the shopping cart for pricing & shipping cost.
Apr 20, 2011 | Master Heaters B155DST
Underhood fuse panel on a 1994 Chevrolet Suburban K2500
Under the hood driver side close to the master cylinder and fender, has black cover , pull cover off.Hope this was helpful.
Dec 15, 2009 | 1994 Chevrolet Suburban
Where is the fuel pump relay located in a 2003 ford explorer
in the underhood fuse box just beside the master cylinder the fuel pump relay location number is 50B, in the same box also check fuse # 23
A 20 Amp Mini fuse for fuel pump power
Oct 28, 2009 | 2003 Ford Explorer Sport
Turn on key no electrial, no lights no nothing, battery is full charge checked all the fuses in side panel, all good Is there a reset button or somthing like that.. Or a master fuse?
Hi and welcome to FixYa,
There is a master fuse. It is 30 amps and is located at the side of the starter motor relay. To determine the location of this relay, follow the wire from the + terminal of the battery. The main fuse is responsible for supplying all the electrical power of the bike except for the starter itself.
Good luck and thank you for using FixYa
Apr 08, 2009 | 2004 kawasaki VN 1500 Vulcan Classic
Looking for the fuse box
Which one? There is one located under the drivers side dash. Then a large fuse, high amp panel is mounted on the firewall in the master relay and fuse panels. Some models have an additional fuse panel under the right side kick panel below dash. What fuse are you trying to locate?
Mar 24, 2009 | 1988 Buick LeSabre
Toyota Camry power windows not working from master switch
Their are two fuses that power this system. One is a 15 amp gauge fuse and the other one is a 30 amp main power fuse. You can also check the power main relay, your ignition switch, or i could possibly be a fault in the wiring
Mar 11, 2009 | 1996 Toyota Camry
Cruise control not working
The switch is located on the lower side of the master cylinder.It has two wires in the plug. Check for brake fluid seeping through it. The wires are LB/BK and OG. Also check the fuses in the fuse box under the dash. Fuse #5 is a 10 amp fuse that feeds this circuit.Hope this helps.
Aug 18, 2008 | 2005 Ford Crown Victoria
178 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Tre Elkins
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
