Question about Mitsubishi Wd-57731 57-inch 1080p Dlp Hdtv
57" mitsubishi rear projection screen hdtv
I was having the power light blink a bunch of times then turn off.. i googled the problem and a few suggestions said to change out the capacitors located out on the DM board.. i located them and replaced them with 4 1000uf/35 capacitors. i then hooked everything up and tried to turn the tv back on.. still green flashing power light. only now im hearing a small clicking sound coming from the board that the power cord hooks into.. not sure where its exactly coming from but my guess is it has something to do with it.anyone ever have this issue.. any suggestions would be appreciated!!
  • ccg129
    ccg129 Oct 25, 2012
    ao does anyone have the error codes list so that if i can figure this out and read error codes ill have an idea where to start.. thanks
  • 1694 Answers
SOURCE: constant green blinking light Mitsubishi tv WS-65513
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Posted on Jan 07, 2008
  • 116 Answers
SOURCE: Mitsubishi WS-65313 - Will not turn on
The most common failure are the two convergence integrated circuits part # 267P173010. The two pico fuses may be open as well, which come from the power supply and provide +24 volts and -24 volts.
Posted on Mar 05, 2008
  • 927 Answers
SOURCE: dm board (power supply) for mitsubishi rear projection tv (ws-55807)
Good day,
mohiuddin;
If the indicator stays on then you may have an DM PCB problem and to correct this do the the folowing:
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Posted on Jul 30, 2008
SOURCE: blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Posted on Sep 19, 2008
toddg
  • 171 Answers
SOURCE: I fixed the blinking light, but still no picture
Here is the correct and official service manual on the unit. Check all of the diagnostics first, then go into the service menu and validate your settings.
http://www.techlore.com/download/22529/MitsubishiWS55859-WS65869-WS55909-WS65909-WS73909/
Posted on Oct 10, 2008
What do i have to replace ? i press the power button and it sounds like its gunna turn on but shuts off and the indicator light just flashes ten times over and over .
thanks for the buick help, as for your sony, google tv repair or problems for your your
exact model and there will be a bunch of sites with parts and so on. most of the
time it is the power supply or/and the capacitors that go! if you are savy with that
stuff, you can fix it! thanks again!
Oct 03, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
I HAVE THE GREEN TIMER LIGHT BLINKING FAST AND TV WONT TURN ON BUT LAST TIME THIS HAPPENED I JUST PUSHED A BUNCH OF BUTTONS AND IT TURNED ON WTF
The DM capacitors have failed. Installing the V26 DM repair kit from www.tvrepairworld.com should repair that issue. Its listed under the Mitsubishi repair kits and contains the capacitors and the CD with detailed instructions.
Dec 24, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony KP-57WS520 57 in. Rear Projection TV standby light blinks
Please mention how many times standby light blinks on your KP-57WS520
There would be bit long pause between blinks so count the blinks and let me know to help you.
Dec 05, 2008 | Sony KP-57WS520 57" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Set turns off randomly
there is a capacitor right behind hori output transistor it most of the time goes bad 1200pf 2k volts,yours could be on its way out,when it does set will not come back on.
Jan 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Mitsubishi Wd-57731 57-inch 1080p Dlp Hdtv Logo
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
