There is no video signal from the opticum X80 pvr box in my hotel room
What sized beds are typically found in hotel rooms?
In hotel rooms, you usually have the option ofchoosing between queen and king d bed as the main bed in the room.
Jul 30, 2012 | Furniture
I was given a JVC TV, model # AV2648S. Will this TV receive a digital broadcast from our cable subscriber or will I have to get a digital box for the TV?
Hi, Yes it will recieve digital signal. But you will need a set top box from you cable company.
You can rent or buy it. You can get a (PVR) which is a personal video recorder. With the new digital signal you will not be able to use your VCR to record videos. Only watch them. Good luck.
Jul 31, 2011 | JVC Televison & Video
No signal for 5 days. aerial works in television
Off/ON signal U well get ur signal back.Make sure U have plug in tight have power all the times.
Aug 13, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Error code 09
Er00 - The software that was available for upgrading was of an older or of the same version as the one already in the digital-box.
Er01, Er02 -The upgrade failed. Some information was missed out.
Er03 - The internal memory is not large enough to receive the upgrade.
Er04 - The signal was disturbed during the upgrade.
Er05 - Wrong type of data was received during upgrade.
Er06 - Not used.
Er07 - Access problem in back-up memory (EEPROM).
Er08 - Access problem in video memory.
Er09 - Can not find any data to do an upgrade.
Er10 - Poor or no cable-TV signal.
Er11,12 - Not used.
Er13 - Unauthorised data signals received by the digital-box.
Er14 - Faulty data signals received by the digital-box.
Pb01 - A problem in the ROM memory is detected.
Pb02 - Memory size is too small.
Pb03 - A problem occurred during start up (initialisation
problem).
Pb04 - Internal communication failure.
PbF9 - Hardware error identified during start-up
From elsewhere on the web:
1. Turn off the unit for 15 minutes to cause a full reset.
2. Turn on the PVR with everything attached except the antenna input.
3. You will get an Er09 on the display. On my PVR there was no output on the TV screen whatsoever (totally black screen).
4. Press 'OK' on the remote (confusing as there is no clue that this is what you should be doing, though Sagem support thought that the PVR should prompt you.
5. The box reboots in standby mode."
Good Luck...
I also see some mention that if the above procedure doesn't work, try pressing "Menu" twice to see if that clears error 09.
Mar 05, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Xbox and laptop
your stuck unless the pc has HDMI output
regards
Dec 22, 2008 | Compaq Presario 5000 PC Desktop
Televison & Video Logo
Top Televison & Video Experts
