Question about Gateway SHD-3010 30 in. HD-Ready LCD Television
Gateway shd 3010 LCD goes black
I bought a used gateway shd 3010 LCD and after turning it on, the screen goes black but I can still hear audio. I turn it off and back on and the picture returns....yet 2 to 10 minutes later it goes black again. The process repeats for maybe 8 to 10 sequences and finally stops with a steady picture. Is something not warming up or do I have a defective part?
Thanks in advance
  • Anonymous Jan 19, 2009
    Whenever I turn on my tv, I have great sound however no picture. Is there a part that I need? Please help
  • jshadrick Apr 18, 2009
    same problem flash no pic but sound
I have the same problem now!!! Did you ever find a solution?
Posted on Aug 30, 2011
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I bought a used motherboard from ebay.After a month it turned black screen again so can u help me
So you replaced the motherboard.
Well the systems are like laptops so you need to check LCD cable inverter and the LCD screen.
eres one that had a motherboard problem but the screen seems ok.GATEWAY ZX4300 01E ALL IN ONE AS IS FOR PARTS <<< i buy part as is when it system don't power up because its not screen related.
or pay seperate
Gateway All in One ZX4300 41 Inverter Board
Gateway All in One ZX4300 41 Inverter Board Cable DD0EL2IV000
Gateway All in One ZX4300 LCD Video Cable DDEL2CLC000
check if the system is compatible.
May 13, 2014 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Black screen blue light blinking
LCD backlight is faulty. Need repair.
Oct 25, 2013 | Gateway HD1900 19" Monitor
Screen turns on then turns off
If the unit is under warranty, take it back!
If it's not, and you are tech savvy, start looking for bulging or leaking electrolytic capacitors in the power supply and inverter sections of the TV.
This is almost always the issue in a case like this, and replacing those bad caps should fix you right up.
Otherwise, it's time to take it to a shop, or just get a new one.
Feb 24, 2011 | Gateway SHD-3010 30 in. HD-Ready LCD...
Montior goes black i turn off the monitor and turn it back on i can do about 2 things and screen goes black again repeat this as many times as i want. Gateway FHX2300 monitor
My monitor has been switching connections on me randomly. Hit the menu button. The one to the left of the power butter when facing the screen. Hit the left arrow twice then hit the menu button again. This will open up the screen where you can choose one of three inputs. I'm going to assume that it is on the incorrect input so use the arrow keys highlight what input you are using and the hit menu button again and your screen should return to normal. Mine only does this randomly when it goes into screen saver, hibernate or sleep. I don't know how to permanently get it to stop doing it though.
Aug 23, 2010 | Gateway FHX2300 LCD TV
Audio but no video
Sounds like a bad lcd panel (inverter boards) are part of the lcd panel.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I have an shd-3010 with the remote and the channel button doesn't work nor do the buttons to change the station on the remote. Yet the power button works as does the volume buttons
Here is the solution. I have had this problem for 2 or 3 YEARS... (I finally gave up and just changed the channel manually).
The solution is exceedingly simple. You'll want to punch yourself (or at least, I did... :-P )
Press Menu. Press Menu. Press Menu (3 times total)
THEN, scroll down to "Channel Fix"
It will say either "3" or "4." What this does is it makes it so that your HDTV is always on channel 3 (or 4) when you turn on the device... AND it apparently disables the channel functions of the remote control, for some inexplicable reason.
All you have to do is change this setting from "3" or "4" to --> "OFF"
You will now have full channel and button control.
Enjoy! <(^_^<)(^'.'^)(>^_^)>
Jul 17, 2009 | Gateway SHD-3010 30 in. HD-Ready LCD...
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Gateway SHD-3010 30 in. HD-Ready LCD Television Logo
217 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
