Question about Mtd 22" Yard Machine Push Mower
I have a craftsman rotary lawn mower model 917.388190 and when I try to mow it runs ok than slows down.Can u tell me what is wrong with it ?
  • Mtd Master
  • 7,482 Answers
Hi louise
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 30, 2012
  • 57 Answers
SOURCE: lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
Posted on May 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: nannie what can be wrong with my power devil
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Posted on Jun 23, 2009
bbreton
  • 437 Answers
SOURCE: riding mower will barely move
Sounds like it time for a tuneup. Air filter changed, Spark plugs replace and oil changed, plus sharpen the blades while you are at it.
Posted on Sep 26, 2009
wilsodfarm
  • 986 Answers
SOURCE: Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Posted on Oct 10, 2009
  • 279 Answers
SOURCE: I can start the lawn mower but it will stall if I
First thing I would check is the air filter. Then the belt that drives the wheels. Open up the belt area and clean. Last I would check the carb. Good luck...Lee
Posted on May 28, 2010
Testimonial: "Great Job followed each suggestion & was able to mow the rest of the lawn...this guy knows his stuff !"
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Power loss
sounds like the engine is running lean caused by dirty jets inside the carb
Aug 08, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My Cub Cadet 1054 is losing power significantly
is the engine speed ok but the mower speed slowing down check the belt tension
Apr 04, 2012 | Garden
I have a Craftsman lawn tractor, model # 917.276180. After mowing for about an hour, the transmission starts to slow down and eventually stops. The tractor s/n is 03006D006025 and was purchased new from...
Hi, remove the battery and battery carrier and clean all grass and debris from the hydrostatic drive, cooling fins and fan. I'm not sure what transmission it runs but the solution applies to all. Hope this helps, regards Phil.
Aug 25, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My lawn mower won't start. It needs oil. It
Yes... most have oil sensors which shut them down bwfroe damage is done...and if not what can it hurt now???
Put oil in it and try it..
heatman101
Aug 04, 2011 | Craftsman Garden
Mower shuts off while mowing grass
Check the switch that is located under your seat. If you are not on the mower while it is running the switch tells the mower to shut off. hope this helps
Jul 12, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Mtd 22" Yard Machine Push Mower Logo
270 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
