When I turn on my laptop I have to keep pressing F12 to get it to boot up.If I dont press F12 it turns on with a blank screen.
SOURCE: Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
SOURCE: Slammed ZToshiba A135-2276 will not boot
I'm not sure why you slammed the system shut, bu if it was to do with a system performance issue, the most likely answer is that the hard disk drive is or has failed.
If running Windows XP, boot to recovery console, see if you can run chkdsk on the drive. If Vista, boot to the DVD and run repair my computer.
Most likely, if those options do not get the system to boot, a hard drive replacement may be in the cards.
SOURCE: Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
SOURCE: Regarding Hp Pavilion Tx 1000, the laptop now
check the setting in bios or if you do not know very well the bios just putt it on default settings problem solved.
Insert the Toshiba A60 recovery disc into the CD/DVD-ROM drive.
Power off the Toshiba (with the recovery disc still loaded inside the optical drive).
Release the "F12" key when the" In Touch with Tomorrow TOSHIBA" screen is displayed. This will open up the BIOS.
Change the boot order by using the arrow keys to select "CD/DVD ROM" icon in the menu. The Toshiba will now boot from the recovery disc and restore the system. Follow any additional on-screen instructions.
