Question about Eiki LC-SE10 Projector Multimedia Projector
Why won't my warning light turn off?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Posted on Apr 17, 2014
Bulb failure warning won't turn off
I would Double Check, High/Low LEFT/RIGHT/BRAKES/ Everything...
Apr 10, 2013 | 1998 Volvo S70
The 'key in ignition' warning sound won't turn off and my battery went dead. How do I get it to turn off?
Pull the Battery Post off the Battery then the fuse If that don,t work Cut the Horn Wire To It
Mar 04, 2013 | 2004 Ford Windstar
2001 Chev Malibu. Turn key on to start car, won't start. No warning lights on no lights on gauge panel. Radio works, dome light work.
check the ground leg to your engine.. it runs off the neg. battery terminal. will connect to frame and engine.. pull it off, wire brush it put it back.. you radio will work, 'cause it draws much less current, and is grounded in dash.
Jan 11, 2013 | 2001 Chevrolet Malibu
Door chime and open door warning light won't turn off
more than likely you have a bad door switch check the driver side first
Dec 05, 2012 | 2005 Hyundai Sonata
Warnimg brake light
What does the owners manual say the light is for ?
It won't go off until you diagnose & resolve or
repair why it is on.
When you ask a question we need lots of detail
We can't answer every question when a light comes
on & you don't provide a vehicle,engine & all the details
in the manual about the light & the vehicles driveability issues
Nov 15, 2012 | 2007 Toyota Matrix XR
MY PLYMOUTH GRAND VOYAGER 'S HEADLIGHT'S AND DASH LIGHTS WORK, BUT THE ENGINE WON'T TURN OVER. THERE IS NO SPARK COMING FROM THE ELECTRICAL WIRES.
When you say no spark, are you talking about the spark plugs, or just the general wiring?
If the engine won't turn over, then it isn't moving, and if it isn't moving then you need to check the following in this order:
1) Does the battery have power i.e. around 12.4 volts or over?No? Charge, test or replace battery.
2) Do the car's head lights dim considerably if turned on when attempting to crank? Yes? Possible lack of battery charge or faulty battery.
3) Assuming the battery is fine, can you turn the dash warning lights on and off with the key? No? Faulty ignition switch.
4) Is there a click sound when you turn the key, but no starter motor spin? Check starter motor connections or replace starter motor.
If none of the above prove to be of help, then please report.
Oct 31, 2012 | Plymouth Cars & Trucks
What causes abs and warning light come on and off ramdonly on e39
You won't know the answer until you do something,
like check for codes & diagnose any codes related
issues & correct them first
Too many components in that system to guess at
a couple of common things,as you need to get to
work on having it checked out by an experienced technician
Aug 30, 2012 | 2001 BMW 5 Series
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
Wanting to buy a 1998 lexus ls 400 after replacing the battery the dash lights up but the engine won't turn.. What could be the problem
Are there any warning lights on in the dash, may a security warning light? If so you will need to reset the security system, refer to the owners manual or callthe local Lexus dealer for instructions.
Feb 07, 2012 | 1998 Lexus LS 400
Eiki LC-SE10 Projector Multimedia Projector Logo
129 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
