Question about Toshiba Satellite A105 Notebook
I can not reboot my toshiba laptop
Ok i have a a cd called xp performane i do not know if i could used that cd to reboot my toshiba laptop.. if i could reboot with that cd can anyone give me step on how to reboot it or a little advice about that cd called xp performance
I forgot my password and i dont know how to reset my toshiba satellite l25
Don't worry about it , I know the easy way to recover windows password, you can use the software called Smartkey Windows Password Recovery which is easy and effective to operate, and you can download and seethe using method from
It can support Windows 8, 7,Windows XP, XP+SP2, XP+SP3, 2000, 2003, 2008, NT, Windows XP Professional x64Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems,Windows VISTA, Windows VISTA(64-bit).I hope it can work out for you.
May 09, 2012 | Toshiba Computers & Internet
How can I unlock my toshiba laptop
At some point, you'll encounter a password issue on your Toshiba laptop computer for several possible reasons. For instance, you may have decided to go back to the old laptop, and it's been a while since you last logged into it. Forgetting a password is also common if you tend to create different codes for various uses: email, network administrator user information and bank account details, for instance. Should you need to unlock a Toshiba laptop computer that runs on Windows XP, here is what you can do.
1.Use a Windows installation CD to reset your password for your Toshiba laptop computer. This is the same one that you got when you purchased the computer. Boot the laptop using the CD in the same way that you would go through a re-installation for your operating system. Simply insert the CD into the CD-ROM drive and wait for the computer to read it. From there, you will get a prompt that says "press any key to boot from CD," so you just need to follow as instructed.
2.Repair Windows. Once the CD starts up, you will get to a screen that will ask you whether you want to "Install Windows" or "Repair Windows." Press "R" to repair. The computer will then reboot itself after copying files from the CD into the Toshiba laptop's hard drive.
3.Get into the control panel. After the computer boots up, you will encounter a screen that will say "Installing devices." To open the command prompt, press the keys "Shift + F10." On the command prompt, type in "nusrmgr.cpl."
4.Change your password. Getting into the control panel will allow you to change your password using the administrator's control panel utilities. Just go through the process of designating a new password to unlock your Toshiba laptop and then exit the command prompt.
5.Restart the laptop and try logging back in using the new password.
6.Log on without the Windows XP installer. If you don't have a Windows bootable CD, use another computer with internet access so you can create an emergency recovery disk (ERD) that will allow you to unlock a Toshiba laptop. Browse through the internet and search for ERD software.
7.Burn the ERD program into the blank CD and use it to reboot the Toshiba laptop that you want to unlock. The computer will automatically detect the program, so it will take you to a series of prompts where you can change your password.
Sep 24, 2011 | Toshiba Computers & Internet
Will resetting toshiba get rid of viruses?
Yes, reseting your laptop to original setting is possible.
It is called as formatting.If you format all the content in laptop will be lost.Please take back up and then format it.
Please get the boot up CD for your operating system(windows 2000 ,XP)
Put the CD in drive and restart the laptop.
It ask 'reboot from CD'.
Give enter it will start formatting the laptop.After formatting the laptop will be brought to original settings
Jul 24, 2010 | Toshiba Satellite A100-S8111TD Notebook
Have purchased before 3 year a laptop . my laptop model no is Satelite Pro A120/ PTA 83L-04902N . Now due to some virus affected i have to format and reinstalled the software. But unfortunately i have...
You normally get recovery cd with your laptop.
ok you can use a win xp cd from friends or relatives and use the serials from your laptop to install the os.
ok you can also try
best luck.
Dec 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Sep 07, 2009 | Toshiba Satellite Pro L300 Notebook
I have a Toshiba Satellite laptop with a SD-R2512 DVD drive that the unit will not recognize. It sees it in device manager and says that the drive is missing...code 39. I tried to delete it in that...
Seems like the DVD drive went bad.
My advice is try another DVD drive and install it on the same laptop. just to make sure the laptop is ok.
Please don;t forget to rate is this answer helps you in some way
Jun 25, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Toshiba Satellite 1115 S103 can't install Windows XP home edition
after it reboots it will ask you to boot from cd,
ignore this and let it boot from harddrive, where it has already copied the files to... it should setup ok from there
Apr 06, 2009 | Toshiba Satellite 1115-S103 Notebook
Looking for wireless on switch on laptop
Right Side, underneath your volume control. If it is switched on and still cant access the internet wireless give this a try.
Use Control Panel's Add or Remove Programs utility to uninstall the Toshiba Hotkey Utility, and then reinstall it.
This program is called E-Key Utility on the Toshiba Satellite M30X/M35X Recovery and Applications/Drivers DVD. It's called Toshiba E-Key Utility for Windows XP on the Toshiba Support website.
Unistalling the Toshiba Hotkey Utility:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
  4. Select TOSHIBA Hotkey Utility.
  5. Click Change/Remove.
  6. Click OK to confirm that you wish to completely remove the selected application and its features. The InstallShield Wizard will begin the removal process.
  7. Click Finish to exit the InstallShield Wizard.
Re-installing the Toshiba Hotkey Utility using the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD that shipped with the computer:
  1. Insert the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD into the CD/DVD drive and close the tray. The setup program on the DVD should start automatically.
  2. When the Toshiba Recovery and Applications CD window appears, verify that "Install applications and drivers" is the selected install type, and click Next.
  3. Select E-key Utility from the list, and click Install.
  4. When the WinZip Self-Extractor window appears, click OK.
  5. Click Unzip.
  6. Click OK to acknowledge that the files were successfully unzipped.
  7. When the InstallShield window appears, click Next and follow the prompts to complete the installation.
  8. When the installation is complete, click Exit and then OK to close the Toshiba Recovery and Applications CD window.
  9. Remove the Toshiba Satellite M30X/M35X Series Recovery and Applications/Drivers DVD from the optical drive and close the tray.
Reinstalling the Toshiba Hotkey Utility using the file downloaded from the Toshiba Support website:
  1. Download the Toshiba E-key Utility for Windows XP from the Toshiba Support website, and save it to your computer. See also the bulletin Obtaining downloads and support docs from the Toshiba Support website.
  2. Navigate to where you saved the file and double-click it.
  3. Click Run.
  5. Click Unzip.
Feb 21, 2009 | Toshiba Satellite M35X-S111 Notebook
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Toshiba Laptop Malfunction!!! PLEASE HELP!
Hi Sam
First of all sorry to hear your story. But I guess you shouldn't think there is no solution left. I am Toshiba Technical Specialist and I used to work for Toshiba. Toshiba recovery CD is obtainable from Toshiba. you can call their hotline number or you can go to Toshiba authorized dealer. Recovery CD Cost about $39 including shipping. Alternately there is no harm to use different XP Operating System as long its correctly installed. But for the drivers you need to download from (if you dont use the Recovery CD)
If you need further info please post your request.
Good Luck
Dec 26, 2007 | Toshiba Satellite M45-S265 Notebook
Toshiba Satellite A105 Notebook Logo
274 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
