Question about Philips MWD2205 DVD Player/VCR
Vcr not playing tapes, just ejects them
My dvd player on this product works perfectly, it's the vcr i'm having trouble with. when i put in a tape the unit shuts off. then when i turn it back on, it automatically ejects the tape. even if i put the tape in and hit play quickly or put a tape in that should auto play the unit still shuts off and ejects tape. sometimes when the tape is ejected the actual tape inside the cartridge gets stuck inside the unit on something and i have to wiggle my hand through and release it. this leaves places on the vhs tape that when it is played on a working vcr it is static and messed up sound. help?!?!?!?!?!?
  • 1 more comment
  • kristy spence May 14, 2007
    philips MWD2205 DVD Player / VCR Combo about a year old
  • kristy spence May 16, 2007
    thanks for the info, but i got the unit for about $70...so it is now a dvd player only. appreciate the input though!
  • VCR_Neophyte Feb 06, 2008
    I have a JVC brand VCR about 11-12 years old. It has worked well up to now and gets regular use taping off the TV. Suddenly, last night when I put in a blank tape, the tape sat in the space for a few seconds with the flap open then it was ejected. I've tried other tapes with same results. I unplugged the machine from the wall outlet and left it awhile, but this didn't change anything. I also wiggled all the connections in the back of the VCR. I also checked all the programming for time/date, etc. on the VCR and they were unchanged.
    I had just bought a used (good condition) movie and played it part way through - could this have affected my VCR?
    Problem Solver:
  • 15 Answers
Not enough info. What is the product? Brand, model, how old?
Posted on May 13, 2007
  • Kevin Brown May 16, 2007
    dingbatkms,
    I had a probalem similar to this a few years ago. Me being an engineer, I searched and searched for the problem. Finally broke down and took it to a repair shop....turned out a voltage regulator was bad (I had checked the voltage and compared it to the value stated in service manual, it was slightly low, but did not think it should be a problem.) Anyway repairman just swapped circuit boards until problem went away. Cost me ~$50. Good luck.
    Problem Solver:
  • 4 Answers
Zv427m9a 2 yrs old. Upon opening the case to get at the stuck tape I noticed brown liquid (from heat) over the bare jumper wires behind the heads. This unit has a direct drive capstan motor with a good belt to the take up and supply hubs. The load motor is fine as are the heads. In this case I believe a cold solder joint or overheated component on the under side of the circuit board is the culprit as the power supply is ok.
It is probably not worth bringing to a repair shop for more than a $50.00 repair.
Posted on Apr 03, 2013
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Close when play vcr
Problem in the mechanism that moves the tape in play,ff,rewind and also winds tape back into cassette and ejects it.
Likely a bad or worn belt or drive idler(rubber).
Nov 04, 2012 | Televison & Video
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
VCR accepts tape, then turns off
I think that there is something wrong with the tape you are using. The locking mechanizm is stuck and when the VCR can't turn the reels it will eject the tape. I'm assuming that you didn't try other tapes to see if it acts the same. You can unstick the locking mechanizm by putting a pencil or something like it in the 1/4" hole between the reels on the back side of the tape. Just try pushing down on that brake release. This has worked for me. Good luck.
Jul 04, 2008 | Zenith XBV243 DVD Player/VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Philips MWD2205 DVD Player/VCR Logo
1,143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
