Question about Moultrie Gamespy I45 Infrared Digital Camera Game Spy
I have a moultrie gamesky i45 and it wont take pictures. Worked great last year but now doesn't. I think it may be loading pictures right on camera instead of sd card
SOURCE: sd locking
I had this problem also. To solve the problem I blew into the slot where the card goes and it then read the card. If dirt gets into the port it causes the sd card to lock. You may have to use a pressurized can of eletronic spray to clean the port.
It worked for me.
Posted on Mar 04, 2009
  • 296 Answers
SOURCE: Moultrie DGS160 Game Camera Error 20000
Forget calling Moultrie...I think their answering system is permantly set for "off-hour" times...you may have to e-mail them several times be fore (after4-5 days they get back to you.
You're error should read error"0200000"...flash error or flash charging...getting this during system diagnosis probably is that you failed to cover sensor during ck.
I f this is a constant error...turn cam on; remove batteries; turn system off; insert batteries and try again. .
Posted on Feb 17, 2010
  • 296 Answers
SOURCE: I have (2) DGS-200 Moultrie cameras that the LCD
WWW.MOULTRIEFEEDERS.COM WILL SEND REPLACEMENTS AND INSTRUCTIONS FOR FREE....
  • 296 Answers
SOURCE: user manual needed for a moultrie mfd-cdc model
here's your manual:
http://images.ebsco.com/pob/Moultrie/catalog/GameSpy100V2Manual.pdf
Posted on Feb 20, 2010
  • 296 Answers
SOURCE: Moultrie I450 Game Spy
Before installing a sd card, internal memory MUST be erased. From setup,use the up/down buttons near the select button until the display reads "ERASE ALL PICS(MEMORY)? NO" toggle up or down button to get"YES", press the select button and wait until until it says "DONE".
Go to setup screen, power off, intall sd card...should be good to go.
Posted on Mar 06, 2010
I have a moultrie model # MFH-DGS-D55IR when I plug in the camera to my computer it no longer transfers the pictures automaticly.How can I fix that
have you clicked "computer";checked for a removable drive,possibly id'd as "drive K,L,or Moultrie";double click;pics should be in file 100DCIM, or something like this...try plugging USB from camera in a different port;try reading directly from SD cart if you have a SD card reader...sometime Windows doesn't auto-load removable devices.
Nov 27, 2011 | Moultrie D55IR Digital Camera
The camera worked for two months and took a lot of pictures. Now the LCD screen will not display. I replaced the batteries and installed a new SD card. I reset the camera and it still will not work. The IR...
It's probably the small ffc(ribbon cable) connections from control panel to main board...remove top to access control panel;remove 5? screws and CAREFULLY lift control panel from camera...ribbon cable is obvious...it connects at both ends to zif(zero insertion force) connectors...EXTREME CARE HERE...the small brown part lifts to remove pressure to cable and cable can be GENTLY removed...try re-inserting cable CAREFULLY to align conductors with contacts.
Sep 07, 2011 | Moultrie Game Spy I-45 Ir Game Camera...
I need to download the plot stalker software from online cause my computer doesn't have a cd drive
On the Moultrie website in the menu at top left click on minicams...opens to show the M80, M100, and another...I clicked on "full details" below ad for the M80; opened to caera details; scroll to bottom and click on software downloads...should show Plot Stalker M80, M100,I45...I have downloaded and extracted but haven't tried it out yet.
Sep 02, 2011 | Moultrie Game Spy M80 Infrared Digital...
My camera is taking picture after picture and only stops when turned off. I have the I45 Camera.
your camera has a faulty ic that needs replacing. had the same problem with a sony digital camera too.
G.
May 29, 2011 | Moultrie I-45 Digital Camera
I have a Porter Cable pancake compressor Model CFFN250N-2 which worked great last year. This year I turn it on and it just continues to build pressur euntil the safety valve blows.
i think you have a problem with the pressure control. unplug the compressor and open the controller. check all the connections and really look it over. these pressure switches today just do not hold up well. sometimes there is enough moisture in the unit that it can freeze over winter and crack. if yours has a plastic hose to connect then check that over as well. check this site. they have a good parts break down ans look ar parts 111and 112 and 113. all called pressure switch service kit.
http://www.ereplacementparts.com/porter-cable-cffn250n-type-compressor-parts-c-129_1662_3092.html
Apr 24, 2011 | Porter Cable Air Tools & Compressors
I have a model 140 moultrie game camera and the display is not viewable i get bits and pieces the batteries are new.
Man i hear ya. I have the same camera and it didnt even last a full year. Same problem you got plus it wont take pictures. I just bought 2 new game cameras and they werent moultrie i can promise you. My bro.inlaw sent his in and they gave him a new one since it was under a year old, however i didnt know you could do that until mine was over a year old and it was too late.
Oct 29, 2010 | Cameras
Model D40 Moultrie camera. LCD screen only shows dots, not legible words. Batteries are brand new. Camera is less than a year old.
may be it's a lcd problem see the manual it guied you to the depth
if not contect your service provider neairest you
Sep 21, 2010 | Cameras
Moultrie dig cam-digital screen on cam has lost partial letters
A known issue....contact moultrie (www.moultiefeeders.com)...they will send you new one free of charge; free shipping
Nov 26, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Moultrie Gamespy I45 Infrared Digital Camera Game Spy Logo
26 people viewed this question
Top Moultrie Home Security Experts
Anthony Pattay
Level 1 Expert
 Mikey
Mikey
Are you a Moultrie Home Security Expert? Answer questions, earn points and help others
