Question about Belkin (F5D7230-4) Router (587009)
Someone pressed the reset button on my belkin n600 db n+ router, and now I can't get it to work with my laptop! Help
  • 2,878 Answers
It just clears any custom settings, and the laptop IP may still be cached (in memory).
From the laptop go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it. Remember custom network and password are gone.
There is a paper tab underneath the unit with the default wireless name and password.
Use a network cable computer to access web interface. 192.168.2.1 to see that information as well. No user or password for the web page.
Posted on Oct 26, 2012
  • 20 Answers
SOURCE: Belkin Wireless G Plus MIMO Security Problem
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Posted on Oct 31, 2007
rwandrew
  • 115 Answers
SOURCE: lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Posted on Jan 25, 2009
  • 82 Answers
SOURCE: Belkin G Wireless Router Not funciontoning: Power Light is Off
Its dead Jim.
I had one of those. Dead.
You can try hitting the reset button. Looking at the back there should be a small hole with a tiny button. Use a staightened paper clip or other object to hold it in for at least 30 seconds. That should set it back to factory defaults.
Doing that brought mine back to life momentarily , but it kept going out after a couple of hours and I had to repeat the process until it finally gave up the ghost for good.
Posted on Mar 05, 2009
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
Posted on Apr 28, 2009
Geekman
  • 32281 Answers
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Posted on Sep 29, 2009
How do you reset belkin router?
Using a opened paper clip there should be a little hole to put in the papclip and depress a little switch. If you can find this then unplugged the power, push in the button hold while reconnecting the power. Whatch the lights and they will flash and then go off and look like nornal.
Nov 12, 2014 | Belkin Components Belkin F9K1102 N600 DB...
I need to configure a N600 Belkin router. How?
Reset the Belkin router -
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 21, 2013 | Belkin Play N600 Wireless Dual Band Router...
My belkin f9k1002v1 router won't work.
A lot of things can keep it from working. Make sure there's lights and you have power, substitute ethernet cables, do a factory reset. Here's how I did the factory reset on my F9K1003V1.
Nov 02, 2012 | Computers & Internet
I changed my Belkin Play N600 to strictly an access point, and now i cant access the settings again
Disconnect the router from the modem and switch off power to the router and after a couple of minutes restore power again.
The router's user name will have remained the same. If you have changed the router's password you need to press the reset to restore the factory default.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com
Sep 03, 2012 | Belkin Play N600 Wireless Dual Band N...
Slow internet belkin 600 db
You can better use the Torrent for Uploading and Downloading flies and videos,the streaming and buffer depends on the site you using for watching video,because traffic increase means you network speed get slow,so better use good and latest browser,reset the modem everyday and check the speed of the internet at here Scanmyspeed.com
Jan 16, 2012 | Belkin Play N600 Wireless Dual Band Router...
My belki router cant work on my computer
Try RESETTING the Belkin back to the defaults and then configure it again.
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
May 26, 2011 | Belkin Basic Wireless Router
Belkin (F5D7230-4) Router (587009) Logo
215 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
