Question about Symbol Batch Barcode Scanner SPT1800 Palm Terminal
Spt 1800 trg screen out of line
Have a few handhelds where the screen is out of line. Have to press a couple of cm above icon to select what you want.
have reset and used any repair tests / tools avail on the handheld.
Thanks
Brian
I Repair the Symbol handhelds. If you wand I can put new screens on them.
Posted on Jan 21, 2009
Malfunctioning keyboard. If touch a letter A a different letter will come up. same thing trying to use the calculater.
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Aug 04, 2010 | Palm Zire 71 Handheld
How do i erase every thing back to how i bought it
  1. Scroll to and select the Settings Icon (to select, press the trackball in).
  2. Scroll to and select the Options Icon.
  3. Scroll to and select Security Options.
  4. Scroll to and select General Settings.
  5. Press the Menu Key, then select Wipe Handheld.
  6. The device is going to confirm that the data will be erased. Select Continue. NOTE: Select "Include third party applications" to include applications which are not included in the original handheld software.
  7. Enter "blackberry" to confirm handheld wipe.
Mar 08, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My son said he added a folder to his 8330 blackberry curve and now all the icons on the front screen and all other screens have dissappeared. I am clueless on what he did. He can still make and recieve...
From the home screen where the icons used to be, press the BB menu butoon, then select Show all and press the Pearl Button.
If that does not work, then download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 11, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
How to master reset a blackberry pearl 8220
To delete all data and applications from your BlackBerry smartphone, complete the appropriate set of steps below depending on the version of BlackBerry® Device Software you are running. Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data prior to wiping your BlackBerry smartphone. If content protection is turned on, the process for deleting all data and applications from the BlackBerry smartphone can take up to an hour to complete. Do not remove the battery from the BlackBerry smartphone while data is being deleted. To identify your BlackBerry® Device Software version go to Options > About (For example, 2.6.x.x, 2.7.xx or 4.0.x.x) For BlackBerry smartphones running BlackBerry Device Software version 2.6 Note: If a password is already set go to step 5. On the Home screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. In the Password field, press the Space key to enable the password. A dialog box prompts you to type a password with at least four characters. Type a password. Click the trackwheel. Type your password again to verify it. On the Home screen, click the ?Lock? icon. The Lock screen is displayed. Enter your password incorrectly 10 times to trigger a security wipe. For BlackBerry smartphones running BlackBerry Device Software version 2.7 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld? For BlackBerry smartphones running BlackBerry Device Software version 4.0 On the Home Screen, click the ?Options? icon. The Device Options screen is displayed. Click ?Security?. The Security screen is displayed. Click the trackwheel and select ?Wipe Handheld?. For BlackBerry smartphones running BlackBerry Device Software 4.1 to 4.2.1 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Click Continue. Type blackberry, and then press the Enter key. For BlackBerry smartphones running BlackBerry Device Software 4.2.2 to 4.7 From the Home screen of the BlackBerry smartphone, go to Options > Security Options > General Settings. Display the menu and select Wipe Handheld. Select the Include third-party applications check box if you wish to remove third-party applications. Clear the check box if you do not want third-party applications to be removed. Click Continue. Type blackberry, and then press the Enter key.
Oct 29, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Hand does not show up on menu
The main unit is not receiving the signal from the remote,
It can be a couple of things...
More than likely you have two remote handhelds. You may be using the wrong handheld to choose the options. Try the 2nd handheld.
Check to make sure the batteries are charged and handheld is ON
Make sure the receiver is in plain sight and not blocked
Aug 07, 2009 | Nintendo Wii Console
I need to know how to do a HARD RESET on my blackberry 8700g?
To Sanitize or Clear out all the information in a Blackberry Device
Scroll to select the OPTIONS icon and press [Trackwheel] to select.
Scroll to select SECURITY and press [Trackwheel] to select.
On some units you may have to select GENERAL SETTINGS before getting the next menu.
Press [Trackwheel] again to access the Menu screen for the security.
Scroll to select the WIPE HANDHELD and press [Trackwheel] to select.
Scroll UP to select CONTINUE and press [Trackwheel] to select.
Type blackberry on keyboard to confirm the action press <-| key.
System responds with ERASING INFORMATION.
Dec 25, 2008 | RIM BlackBerry 8700g Smartphone
Spt 1800 hand held - fatal exception error message
It needs internal hardware repair. I have done thousands. Send your number, if you think you would like to have them repaired. Thanks
Dec 11, 2008 | Symbol SPT 1800 Handheld
Access black screen problem
try this!
1.turn on the unit and switch it to play mode( by pressing the button next to th viewfinder.
2. press the menu button
3. select setup (the option with the toolbox icon)
4. inside setup look and select for setup 1(toolbox icon with a number 1 at the bottom)
5. then select initialize and select OK to every ptompt,
6. then it will pop up clock settings.
if this will not work then it would be better to hav the unit checkd and repaired by an authorized servicer. sony 1800-222-7669
Jan 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Coloured line about 3 cm wide down right side of screen ACER 1640 widescreen laptop
The only other thing that can be done to check that it's not a software problem is to go to my computer>right click>properties>hardware tab>device manager and look down the list for 'Display Adapters' and click the '+' sign and right click and select uninstal. Restart the laptop and the graphics adapter will be installed automatically and the driver installed. see if there is any change. To find out if it is a driver fault, press F8 on startup and select 'Start Windows In Safe Mode', this will boot the laptop without the graphics driver (VGA mode,all the icons will be large sized), so if the screen stays the same you know it's not the driver. If none of above fix the fault then the screen is faulty.
Apr 17, 2007 | Acer Aspire 3000 Notebook
Symbol Batch Barcode Scanner SPT1800 Palm Terminal Logo
328 people viewed this question
Top Symbol Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Symbol Office Equipment and Supply Expert? Answer questions, earn points and help others
