Question about Dell 1130 Laser Printer
When I try to print from the internet, ie directions from maps I get a message to add a printer. What can I do to correct this?
Each time I go onto the internet to print something I get a message and dialogue box asking me to add a printer. My printer works fine printing documents from the computer but not when I go onto the internet.
  • Jacqueline Michaelis Oct 25, 2012
    It is set as a default printer, but I still get that message. Any ideas?
    Problem Solver:
  • 19 Answers
Make sure your printer is set as the default printer.
Posted on Oct 25, 2012
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
After updating to IE9, my printer won't print in grayscale, only color, why?
are you trying to print grayscale copy of the broswer or webpage? or grayscale from word document?
if you are trying to print grayscale from webpage or email, check the version of you IE 9 if it is BETA version or the complete version.It might have something to do with it.
Try using mozilla firefox browser or google chrome as work around.
If there is a smartweb printing software
Disable the HP Smart Web Printing add-on loadTOCNode(2, 'workaround'); To have us disable the HP Smart Web Printing add-on for you, go to the "Fix it for me" section. If you would rather fix this problem yourself, go to the "Let me fix it myself" section.
To fix this yourself, follow these steps:
  1. Close all Internet Explorer windows.
  2. Open a new Internet Explorer window.
  3. When you see the message that states that the "HP Smart Web Printing add-on can cause Internet Explorer to crash or to stop responding," click Always open Internet Explorer without this add-on.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 11, 2011 | HP Photosmart C5280 Printer
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
Connection preferences
If you are connected to the internet using proxy account, you have to add your server name, port number, id, password etc.. But if you just directly connected to the Isp using a username and password, just select "connect directly to the internet" otherwise you'll have trouble signing in to your account.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | Yahoo Messenger
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
Have 2001 quicken running on windows vista. when i try to print the check register, it says cannot open printer. i bought 2009 quicken and started to install, but it said it cannot save old register. it...
Dear Sir/Madam,
To resolve this issue:
  1. From the Quicken File menu, choose Printer Setup, and then select the form that you are trying to print.
  2. Make sure that all selections and settings in the Printer Setup window are correct, especially the selection in the Printer drop-down list.
  3. If all information is correct, click Cancel and proceed to step 4. Otherwise, click OK after making the necessary corrections, and then try printing again.
  4. If the message persists, exit Quicken.
  5. Click the Microsoft® Windows® Start button, choose Settings, and then choose Printers.
  6. Right-click your printer and choose Properties.
  7. Click the Advanced tab, clear the Enable advanced printing features checkbox, and then click OK. Restart Quicken and try printing again.
  8. If the message persists, exit Quicken.
  9. Double-click Add Printer and proceed through the Add Printer wizard until you reach the window that asks for the printer manufacturer and model.
  10. Select the manufacturer for ex. HP, and then select the printer HP DeskJet 550C (or any other HP DeskJet 500 series printer). Follow the onscreen directions in the wizard to finish adding the printer.
  11. Restart Quicken. From the File menu, choose Printer Setup, and then select the form that you are trying to print.
  12. Select the printer you added in step 10 from the Printer drop-down list and then click OK.
Completely uninstall the old version and install the new version. Before install clear registry and temp files. Update the latest driver for printer.
Thanks
Good Luck
Sep 24, 2009 | Microsoft Computers & Internet
Unable to log onto inernet explore
Try clicking Tools > Internet Options > Advanced > Reset. Then click Reset again if you agree to the pop-up window.
Hope this helps. Please remember to rate this information.
Thanks
Jan 23, 2009 | Compaq Presario Notebook
920c does not print the roads in mapquest
You are probably low on black ink as the streets are usually printed in black, if you open up your printer while it is on the print cartridge will move and you can see were it points too. I find that sometimes the cartridge gets plugged up and you need to wipe the bottom of it with a wet cloth and then it works again also give it a shake but make sure you hold onto the bottom or the ink will spray as I found out lol. Also after you do this turn the printer off and on again. You may have to do this a couple times but it finally worked for me! hope this helps.
Nov 14, 2008 | HP DeskJet 920c InkJet Printer
Problem installing lexmark 2650 on toshiba a 30 satellite
did you add a printer onto the computer control panel
did you down load the printer driver from the manufacturers web page downloads
Jun 03, 2017 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
HL-2070N will not properly print
My guess is the problem is with Firefox trying to print the page and not the printer. Try to go to File > Print Preview and see if it looks normal there. If not, I have 3 suggestions:
  1. Try to change the "Page Options" or "Scale" under the Print Preview
  2. Try to install and use the Firefox Add-On "IE Tab". This gives you the choice to display the page with Internet Explorer, while still using Firefox. You can turn on IE Tab, and then try to print. https://addons.mozilla.org/en-US/firefox/addon/1419
  3. Upgrade to Firefox 3.
Mar 21, 2008 | Brother HL-2070N Laser Printer
Dell 1130 Laser Printer Logo
50 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
