Question about Hotpoint Aquarius WMA42 Front Load Washer
Where is the filter in hotpoint aquarius 900 wm61
4 Suggested Answers
SOURCE: replacing door hine on hotpoint washing machine
Its a ***** of a design. Mine is a Hotpoint Aquarius 1200 WD62. If you cant get the backing plate then get someone to tilt the machine right back and you can put your hand under to get it out. Then take the top off the machine(3 screws at the back). Then slide your soap tray right out,(put it to one side) you will then see 4 screws (Which hold in the other tray that holds the soap tray) take these out, you will then need to remove this white plastic tray to get your hand down the machine to reach the place were the backing plate goes. Once u have taken the screws out slide the soap tray holder to the left or right (can't remember) it will then come loose. You will then need to slide it back to lift it out the way (No need to take the pipes off the back of it) you may need to push the whole drum back at the same time you are pushing back the soap holder (Be gentle but it will come out). The holder should then lift up out the way, you can now get your hand down to hold the back plate on whilst you get a helper to affix the door. Make sure backing plate is on the right way, the screws will only go in one way (Check which way b4 u put it down into place). Then go backwards on all steps to put machine back together. This sounds like a load of **** but it worked for me and took about 15 minutes. Good luck!!
Posted on May 15, 2009
barkencoa
  • 3463 Answers
SOURCE: can hotpoint aqaurius 900 WM61 operate from cold
Hi.
Yes it can.
You to purchase an adaptor called a "Y "piece for the washer..
B&Q sell them, they are easy enough to get hold of.
Fasten the straight end of the adaptor on to the cold inlet valve..
Then fasten the 2 inlet hoses to the other 2 connections, and the 2 hoses as normal to the washer,,
Then whatever prog you select, it will draw \in cold water.
All new washers are now cold fill only, so you will be right up to date..
This will solve your problem.
Posted on Dec 19, 2009
  • 662 Answers
SOURCE: Hi. The door seal is split on my Hotpoint Aquarius
For most front-loaders:
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Posted on Jun 08, 2010
Where is the filter on the on the Hotpoint Aquarius washing machine
The filter is inside the machine accessed from the back, see /www.youtube.com/watch?v=R__JTUX9nk4 . Hope this helps
Jun 19, 2016 | Hotpoint Washing Machines
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Hi. The door seal is split on my Hotpoint Aquarius 900 WM61. Could you please advise as how to change it,or is there an on-line giude you could refer me to? Thanks!
Mar 26, 2010 | Hotpoint Aquarius WD640 Front Load...
Can hotpoint aqaurius 900 WM61 operate from cold water supply only
Hi.
Yes it can.
Dec 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hi I own a Hotpoint WM61 machine and water is leaking out of the soap dispenser. Can this be fixed? What part do I need?
The pump filter probably requires cleaning.
Remove lower panel of washer.
Remove large black on bottom of drum.
Removw and clean filter inside hose.
Remove hose onto pump.
Check for blockage or obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 20, 2009 | Hotpoint Aquarius WD640 Front Load...
How do i change brushes on a hotpoint aquarius 900 clothes are still wet after spinning and i have been advised to change brushes
brushes? thats a good un! if its spinning fast its not brushes, it could be the water out pump though, or filter is blocked, even if you did try to change the brushes its no easy job to do, call a guy out to fix it,
Oct 20, 2009 | Washing Machines
Hotpoint Aquarius 900 WM61, washed but stopped spinning, about 6 wks ago, new brushes fitted old 1's had split everything worked fine, 6 wks down the line machine washes but doesn't spin again, bushes are...
hello carl check the module circuit board this controls the speed check the transistor on the boards for dry joints if discoloured change the board all the best
shaun
Aug 04, 2009 | Washing Machines
Hotpoint Aquarius 900 WM61 wont start on any programme.
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2009 | Washing Machines
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
