Question about Frigidaire Dehumidifiers
My continous drain has stopped working on my frigidaire de-humidifier
Has worked, but now does not
Dehumidifier runs but does not remove moisture. Why?
probably the ac section to cool the humidifier is not working
for a de-humidifer to work there has to be a cold surface to condense the water vapour in the air
if there is no ac unit ,it will still need that temperature difference to work or a sufficient humidity in the air to work
Jun 28, 2015 | Frigidaire Dehumidifiers
Why won't my Frigidaire FDF50S1 humidifier maintain its settings?
Hey Art Miner, thank you for your post!
I understand that your dehumidifier is not operating properly. You should put it on a continuous drain mode to see if it will continue to pull moisture. Could you please provide feedback to what your appliance is doing once set to a continuous drain? -Matt
Sep 05, 2014 | Frigidaire FDF50S Dehumidifier
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
Aug 18, 2011 | Danby DDR451 Dehumidifier
Want to run dehumidifier continuously
With most portable dehumidifiers, a hose can be attached to the collection bucket by either removing a cap, or drilling a hole into the hose fitting. If this does not work for your specific model, Searspartsdirect.com or repairclinic.com might have the part that you need. Hope this helps.
Jul 20, 2010 | Frigidaire Dehumidifiers
Hose not draining, bucket only fills
The easiest way to unstop the hose is to blow air through the end enough to clear the clumped up dust at the other end using air compressor or air pump.
Jul 12, 2010 | Frigidaire FDF70S Dehumidifier
Wont run through attached hose
my unit runs but does not de humidify
Aug 03, 2009 | Whirlpool Dehumidifiers
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Dehumidifiers Logo
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
