Question about United Stationers HP Officejet Pro 6500 All-In-One Wireless Inkjet Printer HEWCB057A
My auto doc feeder only pulls in half the sheet and then keeps spinning. Then it says to re load the document. HP 6500. Any sugestions??
    Problem Solver:
  • 19 Answers
Try cleaning the roller in the top of the doc feeder with windex and then try to feed another copy.
Posted on Oct 25, 2012
Why is my photocopier only printing half a page?
Sounds like one of the sensors in the doc feeder that detects the size of the paper has gone bad.
Also, make sure you always close the document feeder when making copies. Sometimes it helps to put a blank sheet of paper over the back of a small object if you're copying something small.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Office Equipment & Supplies
HP Laserjet 3050 all in one
pls clean printer solenoid it wl solve
Nov 27, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
Paper jam in Panasonic KX-
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Lexmark x5320
When you load the document feeder, simply place all of the sheets, up to I believe 25 sheets at a time in the document feeder. The doc feeder, if working correctly will load them one at a time and then exit them to the receiving shelf or tray on your printer.
If you do not have a document feeder, or must use the manual scan function for some reason, there is also a FAX multiple pages function from the sub menu.
ZBob
Jul 28, 2008 | Lexmark C752FN Printer
Paper in document feeder
there is no paper in document feeder
May 24, 2008 | HP LaserJet 3055 All-In-One Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
How do i make a booklet?
Select BOOKLET function, found in SPECIAL FUNCTIONS. Select which size paper is required and then select FINISHER to select STAPLER and SADDLE-STITCH, then load your document into the document feeder. Select number of copies then press start button. All of this is only applicable if a Finisher and Auto-Doc Feeder is installed. Let me know if this helps?
Mar 14, 2008 | Canon imageRUNNER C3220 Color Copier
Document Sheet Feeder
hi im jules_09,check the pick up,bottom plate and feedout motor then the rollers,then the fed belt,also try lobricating the gears,check all parts first before replcing it save you time and money.
Nov 08, 2007 | Ricoh Aficio 450 Copier
United Stationers HP Officejet Pro 6500 All-In-One Wireless Inkjet Printer HEWCB057A Logo
Top United Stationers Office Equipment & Supplies Experts
Dennis
isitmondayet
Level 1 Expert
Gil Shultz
Are you an United Stationers Office Equipment and Supply Expert? Answer questions, earn points and help others
