Question about Water Heaters
Halstead balmoral 55f igniter keeps running no fire up
Halstead 102 combi boiler dhw/ch run for 1second then goes off
You might try cleaning the flame detector. It sits in the combustion chamber and looks like a small bent nail fixed to the burmer [usually at the rear]. Use a medium emery cloth and make sure that the gas holes around it are clean and clear of debris
Apr 18, 2014 | Water Heaters
Halstead free standing boiler ignition working but no hot water or heat?
Does the gas valve click/clunk? In the fan operating. Need to know more
Mar 03, 2014 | Water Heaters
Pressure increase
Could be your expansion vessel needs re pressurising, or it has failed, finally there could be a hole in your heat exchanger, whatever you need a GasSafe engineer to look at it.
Jan 18, 2014 | Water Heaters
I have a halstead finest gold combi when I turn the boiler on the boiler goes into its ignition sequence when it comes to ignite the boiler fires but after the igniter stops the boiler cuts out completely...
Difficult to get too specific without knowing if you have gas or oil. Also, I am going under the assumption you mean the burner shuts down, not the whole heating system. That being said, all heating appliances have whats called a safety curcuit. Each control has the ability to shut down if certain critera are not met. There is a sensor that senses light down the blast tube. If no light is sensed in a predetermined time period, then the sensor cuts power to the burner. This stops delivery of fuel so if it does ignite you wont blow up.
(I suspect that the ignitor and burner shut down simultainously.)
It may be the sensor (cad cell eye) is doing its job, however why is the question. Could be a number of things including the fuel delivery, ignition, improper air adjustment, etc.
No qualified professional should diagnose a problem unless they are in front of the appliance. I recommend you find a licensed qualified heating techician. Hope this helps.
Feb 04, 2013 | Water Heaters
My halstead hero 50 lights but keeps sparking then goes to lockout ? please help
http://www.boschhotwater.com/Portals/7/TechBulletins/TWH-G1-08_Pilot_flame_no_burner_flame_troubleshooting.pdf
This is information from Bosch regarding the identical problem. You can use this for general information, but if you can't make this type of repair, call a service company.
Gary
Dec 15, 2010 | Water Heaters
Heating circuit getting hot when hot water is running
Check to see if diverter valve is in domestic mode or heating mode.
Jul 04, 2009 | Water Heaters
Ignition problems
need to have it cleaned alsp maby fulty thimastat
Jan 17, 2009 | Water Heaters
How to check if pressure switch on halstead boiler 82 combi
Hi I am thinking what your tryig to say is the air pressure switch?
you can check this switch to see if the boiler works by removing one of the sensing tubes from it & by sucking on or blowing as this willactivate the switch you dont have to do it very hard, just gently as you will hear the switch clicking, if the boiler does fire when you click, in order for it to continue to ignite you may have to fold over the tube, when you release it the boiler should stop.if it does work then you will have to change the air pressure switch, but remember this can only be done by a Corgi Engineer
Kindly
Richie
Dec 17, 2008 | Water Heaters
Water Heaters Logo
69 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
