Question about Bio-Rad Biorad Mycycler Gradient Capable
Mycycler lid does not close properly - Bio-Rad Biorad Mycycler Gradient Capable
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Cartrage replacement
From the user guide:
Cartridge Error (1102, 1203, 1204, or 120F)
1 Remove the print cartridges, and close the cartridge carrier lids.
2 Close the scanner unit.
3 Disconnect the power cord from the electrical outlet.
4 Reconnect the power cord to the electrical outlet.
5 If the button is not lit, press .
6 Reinsert the print cartridges and close the cartridge carrier lids.
7 Close the scanner unit.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to
determine which cartridge is not working properly.
6 Reinsert the black (or photo) print cartridge and close the cartridge carrier lid.
8 If the error:
• Reappears, replace the black (or photo) print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit.
• Does not reappear, reinsert the color print cartridge, close the cartridge carrier lid, and close the scanner unit.
9 If the error reappears, replace the color print cartridge with a new one, close the cartridge carrier lid, and close
the scanner unit
Aug 19, 2012 | Lexmark X9575 InkJet Printer
Lid switch shorting somewhere. In this model there is no pin that I can ses. But after removing bezel it flickers but I need the location of the lid switch to check. When opening lid slowly it sometimes...
Probably not a lid switch related problem. In the more modern Toshiba's, the lid-close switch is generally located either above the keyboard area or underneath the front end of the palmrest (towards you), and the lid-close function is activated by a magnet located either above or below the screen. Best way to check if the lid-close function is working properly is to use Toshiba's power management to set the system to go to either stand-by or hibernation upon lid-close - and if the computer goes to stand-by or hibernation when you shut the lid, then that part is functioning properly.
A better, more detailed and precise description of the problem with the screen will probably help in addressing the real problem.
Sep 20, 2011 | Toshiba Satellite P205-S6237 Notebook
Replaced color ink cartridge and now the lid will not close! When I opened the lid to replace the ink cartridge there was a loud crack and now the lid will not close properly.
HI there,
Please check if there are any damage to the cosmetics of the unit.
Ensure that all plastics are properly in place, something must have loosen out when you pull the lid out which also caused that crackling sound that you heard.
Can you please check the sides and the place where the lid and the body closes (joints).
Hope this helps!
Aug 31, 2011 | HP Officejet J5780 All-In-One InkJet...
My pressure cooker always makes a hissing sound. Is that close properly?
As long as the lid is properly locked into position it should be closed properly. A certain amount of air and steam will escape from the valve on the lid and will male a hissing sound but this is perfectly normal.
Jan 17, 2011 | Manttra 38131 8qts Stainless Steel
My Kenmore 400 washer does the following. If I start a wash cycle it goes through entire wash cycle without draining ever, just washes until it ends. If I lift and close the lid when the timer gets...
lid switch stops machine from spinning when the lid is open, Make sure the lid is fully closed. Loose screws on the lids right side not holding metal arm properly, or the arm is not positioned properly (the end which is pointed down when the lid is open needs to be slightly farther away from you, towards the back of the machine, to actuate the switch fully: or the lid switch itself which is underneath the top,
Jan 03, 2018 | Kenmore Washing Machines
The trunk of my car doesn,t shut properly...you have to slam it really hard for it to close properly. I,ve tried W-D40 but that only helped a little. Any sugestions, 98 hona accord
Two possibilities:1) The latch part (the one installed in the chassis, not on the lid) has adjusting screws, these might have become loose, pushed down, and the lid part cant reach it when you close it. 2) The remote cable lid opener might be stuck on the open position, not allowing the lid to lock. Check the remote tab by the driver´s side for freedom of movement, and proper return to rest position.
Sep 27, 2010 | 1998 Honda Accord
Matsui PL700 lid won't close properly
no need to tighten the cap or whatever, that's the problem there is with the switch control, which must be touched when the lid closed. you just need to open the DVD case cover, then locate these switches, make sure the switch is still normal or not, if it is normal that you only need to give a little pad on the suppressor to the switch. suppressor usually exists on the DVD casing.
Jul 26, 2010 | Televison & Video
What does "lid open" mean on the lcd screen? If this happens, can't take picture.
This means either your battery lid is not properly closed. Or the camera lens lid is closed. If camera lens lid is closed you cant take any photo. there will be some knob like thing which you can use to open the lid.
Let me know if you need more help.
Thanks
Sweet rascal
Feb 24, 2010 | Toshiba PDR-M4 Digital Camera
Bio-Rad Biorad Mycycler Gradient Capable Logo
168 people viewed this question
Top Bio-Rad Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Bio-Rad Science and Laboratory Expert? Answer questions, earn points and help others
