Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The green pole is brocken,but the end is inside the female part of the turbine stuck there.Any advice how to get it out ?Model 5914-900
  • hannelore Oct 28, 2012
    Thank you for answering but it did not come out.
  • Hoover Master
  • 18,402 Answers
Get two small screwdrivers at each side and lever it out,or if you ratle it on the floor it shoud drop out, or drill a small hole in it and hook it out...
The green pole is brocken,but the end is inside th - d6c0881.jpgadc2d4f.jpgb64e530.jpg
Posted on Oct 26, 2012
2 Suggested Answers
  • 240 Answers
SOURCE: I followed the trouble shooting
There could be several reasons for this. Remember that the brushes will not turn unless the dirty water tank is in place. Also the handle must be released and tipped back. It is also possible that the rubber seal that the lower tank sits on is missing. If you look down into the motor area, there should be a large, round rubber seal that the lower tank sits on. Look for the round tube that protrudes from the bottom of the dirty water tank. This tube sits against the seal. If it is missing it will need replacement.
Posted on Jul 15, 2011
Brushes not rotating
here is manual > http://hoover.com/file/593/
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaningicon1.png has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plasticlb_icon1.png has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this femaleicon1.png receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the modelicon1.png number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair...
Apr 25, 2013 | Tti Hoover F7412-900 Max Extract Dual V...
My brushes are not spinning
Hi There,
There could be several reasons why your brushes are not spinning. Here's a step by step diagnosis guide so that you may check to see first what is causing them to stop spinning.
If you diagnosis this and find that your turbine gear is broken, here's a link that will walk you through step by step on how to replace the turbine gear assembly:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this problem.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Apr 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes are not rotating
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on front, and 2 in the rear. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose *(one with a spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic pole has not broken.
If the pole is broken, you will simply need to replace the brush block assembly. The model F5914-900 uses Hoover 5 Brush SpinScrub Brush Block Part # 48437022.
Here's a direct link to this part on our GoVacuum.com storefront:
http://www.govacuum.com/hoovsteambru.html
If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Step on the handle release pedal so the SteamVac handle is lowered, and not in the upright position, as there is an internal switch that turns the brushes off when the machine is in the upright position. Now look inside the machine where the pole goes in. There is a green, square shaped female receptacle. This is actually the internal turbine that spins the brush block. Make sure that the switch for the brushes on the top of the machine is turned to "Rotating Brush Speed Hi". Turn the machine on.
If you saw the female receptacle where the brush pole is inserted was spinning, then your turbine is fine. If this part is not spinning, then you will need to replace your turbine.
I hope this helps you with your problem. Please feel free request a clarification request form here on Fixya if you have any questions, I'm always happy to answer follow up questions you might have. If you found this repair helpful, please be sure to rate it helpful by clicking the thumbs up icon. Thank you.
Chris J.
GoVacuum
Apr 14, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes Stopped Working Again, What causes this to happen?
There are several things that can cause the brushes to stop spinning on a Hoover SteamVac. Usually when we see this problem come in, the brushes are usually just stuck to do carpet fibers, or pet hairs that get stuck inside of the brush block. A very easy way to clean these brushes is to take them out of the SteamVac (see the link below that is a full diagnosis of brushes not spinning on a Hoover SteamVac), and use a garden hose that has a spray nozzle on the end, and just spray each and every brush. If you start at the top of each brush, and spray water around the entire brush, each brush should spin pretty quickly from just the power of the water hose.
A lot of the times it's just stuff that got caught inside the brush block that stops them from spinning, I would say 7 out of 10 times this will fix the problem.
It also could be that the brush block is broken, or even the turbine inside of the SteamVac that drivers the brushes could be broken as well.
Here's a link to a Fixya repair solution that I did which will help you diagnosis what is exactly causing the brushes to not spin. If you examine the pole on the block, as well as the square shaped female receptacle, and that receptacle is spinning, then your brushes are just clogged up with debris.
If you need to purchase a new brush block, and you have the model that you listed this repair under, Hoover F7220900, here's a direct link to the brush block on our site:
Hoover SteamVac Brush Block, Part # 48437029.
Here's the diagnosis of the brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red) Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 70% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
Chris Jones
Apr 07, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Brushes are not spinning
Hi There,
When the brush block assembly on a Hoover SteamVac doesn't spin, it can mean really one of three things. First, the brushes are clogged with debris that is not allowing the brushes to turn, second the brush block assembly itself has gone bad, or third the internal turbine that spins the brush inside of the SteamVac has gone bad.
If you find that your brush block has gone bad and needs to be replaced, and you have the same model that you posted your repair under the Hoover F5914-900, Here's a direct link to the exact brush block used in this model:
Hoover V2 SteamVac brush block part# 48437029
Here's a helpful repair that you may perform to diagnosis what is wrong with your machine. This will help you identify which part has gone bad:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See the picture below that I have circled one of the clips in red) Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 70% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing, or the repair of this. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical help you need, just request the clarification request form here on Fixya.
Chris Jones
Apr 02, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Funny sound and funny smell...belt went?
Greetings,
Actually your Hoover SteamVac does not have a belt. The way the brushes are driven is by a turbine rather then a belt. Here's a helpful diagnosing task you may do to see if you need to replace the brush block, or the turbine itself;
Chris Jones
Mar 23, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac v2, brushes won't turn.
Chris Jones
Mar 12, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
HooverSpin Scrub and the brushes always stop spinning.
Greetings from GoVacuum,
Chris Jones
Mar 07, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac scrubbing brushes won't rotate - what do i do
Chris J.
GoVacuum
Dec 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes wont spin
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
I hope this helps you with your problem. If not, please feel free to email me at chris.jones@govacuum.com, and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I do carry all parts for your machine, and would be happy to provide any technical support you need.
I tried uploading the pictures to this solution, however Fixya will not allow the pictures because they are too big. Please email me, and I'll send you the pictures.
Chris Jones
GoVacuum.com
Oct 03, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
18 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
