Volume stuck on mute for wireless speakers
Hi :) I'm having a problem with my new Logitech Mini Boombox wireless speaker set. I have installed a Bluetooth adapter and it works. The speakers and my laptop have paired. However, the volume immediately goes to mute as soon as the speakers and my laptop pair.Windows (Vista) will play its start-up sounds through the laptop's built in speakers, and the wireless speakers beep as they pair. It seems as though everything works, it's just the volume icon in the notification area is suddenly accompanied by a little white cross in a red circle (this is slightly different to my normal mute sign, which is a red circle with a red diagonal line across it with a white background ). If i switch off the speakers, the laptops internal speakers take over and the sound works fine again. I can use the fn keys to control the volume when the computer uses its internal speakers, but when the bluetooth pairing happens, I cannot. If I press Fn and F2 when the speakers are paired, a message pops up onto the screen that says "muting". Hope you can help me! I've tried loads of things already, nothing seems to be working!!
    Problem Solver:
  • 18 Answers
After pairing it, have you tried to go to your sound settings in Control Panel and selecting the bluetooth device as your standard sound device?
Posted on Oct 25, 2012
  • 7 more comments
  • james_hanlon
    james_hanlon Oct 25, 2012
    hi felipe. i have tried that, but i cannot select the "set default" button. it's greyed out (i think that's the expression). any other ideas?? thanks for your help
  • Felipe Varella Beser Oct 25, 2012
    Usually when it's greyed out, that means the device is not connected. Below that there's sort of a status like 'ready'. What it says?
  • james_hanlon
    it says 'working'. i also have a pair of usb speakers which work. actually, there is one other thing: the other playback devices (there are two) listed in the sound settings section of my control panel both have a graphic to the right that indicates the sound level, you know what i mean, like a graphic equaliser display. i am able to test both the usb speakers and the laptop's built in speakers, but not the wireless speakers'. Also, the wireless speakers do not have a level display. i hope you can understand what i mean :)
    i did! on the speakers, after you pair it, the bluetooth light is solid blue?
  • james_hanlon
    yes solid blue
  • james_hanlon
    solid blue on the speakers, no light on the blue tooth adapter plugged into one of my usb ports on my laptop
    Try to right click the device on sound settings and check if it isn't disabled! Also, about your bluetooth adapter, i just did some research here and found out that maybe you need the A2DP (Advanced Audio Distribution Profile) drivers for it
  • james_hanlon
    no its not diabled. felipe, im a bit upset that i might need more drivers. all i want to do is listen to music while i wash up the dishes without having to carry my computer through into the kitchen!! im going to bed now, maybe we can continue this conversation tomorrow. thanks for your help.
    ok, james. dont be upset about it! try to do a quick test with a smartphone when you have the time. pair it with the boombox and try to play some music. so we can be sure that the problem is actually being caused by the bluetooth adapter or some kind of config on windows. have a good night!
4 Suggested Answers
SOURCE: FN keys don't work on Sony VAIO VGN-SZ18GP
The solution is as follows, which worked for me:
- Install Windows 7
- let it update all the drivers that it needs to
- Install additional Sony drivers that you need (XP drivers work just fine, but make sure to install them in Administrator mode, so, Run as Administrator), such as camera, fingerprint scanner, etc
- Install the Notebook Control Device Driver (without this the other software does nothing)
- Sony Utilities DLL
- Sony Shared Library
* restart computer *
- Sony Video Shared Library
- SUS (Setting Utility Series)
- VES (VAIO Event Service)
After this one the Fn keys will start to work. The S1 and S2 keys don't work due to something to do with UAC (but I don't need them anyway)
- VAIO Control Centre (will allow you to change what the S1 and S2 keys do, even though you can't use them :) )
That's it and it worked for me.
Posted on Apr 27, 2009
SOURCE: Some of my function key shortcuts have stopped working
go to asus website and click support. after that click download and find the ATK file...I tried both, but I believe the larger file is the one working
Posted on Dec 18, 2009
  • 27 Answers
SOURCE: Dell Inspiron 1100 Laptop with FN Volume issues.
Starbug1S1- This may have been something you have already checked but I will suggest anyways. You said you had control of your sound from other means - Sounds and Audio Devices properties was one- did you notice a check box that reads Place volume icon on the task bar. This may remedy part of your problem if you put a check in the box. Hopefully this helps. Thanks.
Posted on Feb 11, 2010
Looking for the operating manual for the above model
[PDF]IBC233B Bluetooth Boombox - MCM Electronics
www.mcmelectronics.com/content/ProductData/Manuals/50-9770.pdf
This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful ...
[PDF]Bluetooth Portable Boombox
static.bhphotovideo.com/lit_files/113971.pdf
4. Getting Started. Box Content. • 1x Bluetooth Speaker. • 1x USB Charging Cable. • 1x 3.5mm Audio Cable. • 1x Power Adapter. • 1x User Manual ...
[PDF]Boombox - Logitech
www.logitech.com/assets/.../ue-boombox-quick-start-guide.pdf
LogitechBoombox. Wireless Bluetooth® Speaker. Setup Guide. On your device ... Tap UEBoombox in the list of nearby. Bluetooth ... community of knowledgeable users.
[PDF]Getting started with Logitech® Mini Boombox
www.logitech.com/assets/42627/mini-boombox-qsg.pdf
LogitechAll other trademarks are the property of their respective owners. Logitech assumes no responsibility for any errors that may appear in this manual. ... When "Mini Boombox" appears on the device list of your Bluetooth device, select the.
Jan 04, 2016 | Audio Players & Recorders
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
Apr 28, 2011 | Acer Aspire One Netbook 8.9" Notebook
Hi, I have a logitech lapdesk with speakers. From last few days when I plug it in to USB of my laptop. My laptop use logitech speakers however control for the volume or mute still remains with laptop.2...
Hi nidkap,
My name is Oliver Riemann and I work in the product marketing group for Laptop Accessories. I was disappointed to learn about your recent experiences with the Speaker Lapdesk - this experience is not what we would wish for our customers.
The issue you describe in your mail could have various causes, and our engineers are willing to investigate in order to be able to deliver the best experience.
But we want to help you now. I would be happy to exchange your lapdesk with a totally new one. If this offers suits you, please feel free to contact me via email.
Thank you,
Oliver
Oliver_Riemann@logitech.com
Oct 02, 2010 | Logitech N700
Cant adjust microphone
Make sure your webcam mic is set as default
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Plug the webcam and launch the Logitech dashboard ( toolbar )
Open Settings menu ( 2 gear wheel pic )
Adjust mic to suit
Sep 05, 2010 | Logitech Webcam
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
VISTA
TEST SPEAKERS
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
My speakers seem to be stuck on a very low volume
I have speaker problem no sound but I know its there because when I turn on volume can hear it turn on it was working before my computer is hooked up to magicjack for my telephone different area code then where I live and the other day when I picked up reciver to make a call could hear my speakers on my phone assastance asap PLEASE
THANKS
Marie
Jun 02, 2009 | Logitech X-240 Computer Speakers
Laptop speakers won't work after installing logitech USB speakers
Okay, go to the HP website and download the speaker drivers. It will require a reboot.
Also, try checking the Control Panel Sound Settings if the volume is low from there. This is because increasing the system volume won't work if there is a mute enabled on the speakers themselves.
Also check if the item 'Use This Device (Enable)' is selected. Go to your speaker properties. It is in the dialog box that appears now. Loom at the bottom of it for a drop down menu.
The volume settings are available in the other tabs. Make sure the volume is at 100 and the mute is unchecked.
Please rate this answer. I want to get to a higher level. I am a great contributor to computers in Yahoo! Answers too.
Dec 04, 2008 | HP 2133 Notebook PC
Logitech S-220 Speakers
did you plugin the speakers in the green input? back of your computer?
try to go to controlpanel, and then sounds and check your settings.
good luck
Oct 09, 2008 | Logitech Audio Players & Recorders
Feedback sound, hissing , in speakers logitech X-540
You may want to try disabling/muting the microphone volume in the volume control. If it doesn't help please post back.
Feb 19, 2008 | Logitech X-540 Computer Speakers
Speakers don't respond to volume control
Try cleaning out the boombox. If you're still having problems then they might be bad speakers. Try replacing the speakers. I think they might need desoldering.
Nov 02, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
