Me dnt find wiper motor fuse - Heating & Cooling
    Filmmaker:
    Uploaded 5 video answers.
  • 9 Answers
Check under the hood of ur car it is a fuse box there that houses the fuse for the wiper motor
Posted on Oct 25, 2012
When I turn the switch to my 2006 Cadillac DeVille CTS windshield wiper it does nothing no sound no movement what is wrong
Hard to say what's wrong without testing thing's . Is there B+ voltage to the wiper switch ? B + voltage to the wiper motor ? Do you know how to use a voltmeter ? How to test electrical circuits ?
Here is a factory service manual list of componets involved .
Wiper/Washer System Components
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor
• Windshield wiper motor module
• Windshield wiper/washer switch
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Do you know how the wipers work ?
Windshield Wiper Motor Wiring Tutorial
Wipers Inoperative - All Modes ?????
Wiper Motor Switch Troubleshooting
Sep 05, 2017 | Cadillac Cars & Trucks
Looking for the fuse for the wiper motor 2008 chevy impala
WPR fuse 25amp under hood fuse box .
The Wiper/Washer System consists of the following components:
• Body control module (BCM)
• Wiper PCB relay
• Wiper high PCB relay
• Windshield washer fluid pump
• WPR fuse 25 A
• WSW fuse 10 A
This is more then likely not a fuse issue !!!!!!!
Low Speed Operation
When the wiper switch is in the low speed position, ground is applied through the switch internal resistor and the wiper switch low signal circuit to the body control module (BCM). In response to this signal, the BCM energizes the WIPER PCB relay by applying battery voltage through the wiper relay control circuit to the coil side of the relay. This allows battery positive voltage from the WPR fuse to flow through the switch input side of the WIPER PCB relay and out to the switch input side of the WIPER HIGH PCB relay. Since the wiper high relay is de-energized and its switch contacts are normally closed to the low speed control circuit of the windshield wiper motor, the motor will operate at low speed.
Wiper motor low speed operation and the wiper PCB relay can also be commanded ON/OFF by using a scan tool. Refer to Control Module References.
The PCB relays mentioned above are soldered right into the circuit board inside the fuse/relay block under the hood . There are alot of reasons for the wipers not to work ! The fuse could be blown but fuse's don't just blow for no good reason , short to ground , low resistance high current flow etc.... Intermittant !
Power and Grounds
With the ignition in the ON position, accessory voltage is supplied through the 25A WPR fuse to the WIPER PCB relay, the WIPER HIGH PCB relay and the WS WASH PCB relay that are all located in the underhood fuse block. Refer to Wiper/Washer Schematics.
G200 provides ground for the windshield wiper motor and the WIPER PCB relay. G100 provides ground for the windshield washer fluid pump and the windshield washer fluid level switch.
Dec 04, 2016 | Cars & Trucks
My wiper fuse keeps burning out
If your wiper fuse keeps burning out, your wiper motor might be failing which causes too much amperes required to turn the motor which in turn trips the maximum rated amperes of the fuse.
Follow the wiring of that fuse to your wiper motor to make sure the wiring is not nicked and grounding to the metal. Once you confirm that there is no shorted wire, disconnect the wiper motors wiring connector. Fuse a new fuse and if the fuse does not blow anymore then you isolated the problem which is the wiper motor causing the fuse to blow. Fix or replace the wiper motor.
When diagnosing blown fuses, I usually temporarily replace any fuse in a vehicle with a circuit breaker type fuse. If there is still a short somewhere in the wiring or the component itself in line with the fuse, the circuit breaker fuse will just trip and I just reset it again after I fix the problem. An advantage of keeping to replace a blown fuse while diagnosing.
Oct 04, 2015 | Cars & Trucks
Which fuse or relai controls the wipers motor?
The front wiper motor receives power through the 25A WIPER FUSE in the center console fuse block.
The rear wiper motor receives power through 20A RRWPR FUSE 32 in the center console fuse block.
Jun 17, 2014 | 2005 Pontiac Aztek
Wiper motor montora sport suv keeps blowing fuse
dis-connect wiper motor and replace fuse and try switching wiper motor on if fuse does not blow motor faulty and shorting out and causing fuse to blow.if still blows fuse must be a short in the wiring from wiper motor plug back to wiper motor switch.
wiper motor proberly faulty
May 01, 2011 | 1999 Mitsubishi Montero Sport
Windshild wipers stop working
CHECK FUSE IF FUSE GOOD.HOOK A JUMPER WIRE TO GROUND AND GROUND WIPER MOTOR.TURN WIPER SWITCH ON IF WIPERS WORKS YOU HAVE TO FIX GROUND CONNECTION. IF WIPER STILL DONT WORK.REMOVE THE COWL COVER.TURN WIPER SWITCH ON TO SEE IF POWER GOING TO WIPER MOTOR IF YES.REMOVE WIPER MOTOR HOTWIRE IT.IF WIPER MOTOR DONT WORK REPLACE IT.IF WIPER MOTOR DO WORK CHECK FOR BINDING OR DAMAGE LINKAGES.IF POWER NOT GOING TO WIPER MOTOR AND FUSE GOOD.WIPER SWITCH FAULTY OR IT HAS BROKEN WIRE FROM SWITCH TO WIPER MOTOR.
Oct 04, 2010 | 2002 Toyota Avalon
Windshield wipers stoped working i think it is a fuse. edkk@verizon.net
COULD BE FUSE.IF FUSE GOOD.CHECK TO SEE IF POWER GOING TO WIPER MOTOR.IF YES.REMOVE WIPER MOTOR HOT WIRE IT USING JUMPER WIRES TO CAR BATTERY.IF WIPER DONT WORK IF HOT WIRED.WIPER MOTOR IS BAD.IF WIPER MOTOR WORKS HOT WIRED.YOUR WIPER LINKAGES BINDING. NEED LUBRICATING OR REPAIRED.
Apr 18, 2010 | 2005 Acura TL
Wipers wont work
1.  Turn on your wipers and pop your hood.   2.  If you hear you wiper motor, then you do not need to check your fuses. 3.  If your wiper arms are moving freely, then your linkage from the wiper arms to the motor is disconnected and possibly broken.   4.  If the problem is electrical, do the following:      1.  Check the fuse, and check for power at the fuse.      2.  Check the wiper motor for ground. For a complete circuit, you need power going in and ground               coming out.  Check electrical connections for corrosion or poor connections.       3.  Get a wiring schematic and trace power to the wiper motor starting at the fuse box in the                       following order:           Fuse box           wiper switch           wiper motor      4.  In the rarest of cases a wiper motor or wiper switch is at fault.  I do not recommend replacing                 anything unless you have proof that the part is faulty. (ie. power going into the switch but nothing           coming out.)
Dec 21, 2008 | 1992 Honda Accord
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
