Question about Apevia Computers & Internet
Laptop Charging circuit cuts out
I have an Acer Aspire 5630 with a new battery, and charger, it recently developed an issue where when the laptop is booted up, the charging circuit cuts off, I tested both charger and battery and they work fine, this issue is not software related, so I need to know if I can revive it!
    Novelist:
    Champion:
  • 233 Answers
Yes, it seems that your laptop does not have sufficient wattage for your laptop. So purchase the correct Acer Aspire 5630 ac adapter from prefessional laptop charger online store.You may choose the fit one from the following two chargers on the basis of your laptop model and the detailed specification of original charger and confirm your need a 90w adapter or 65w adapter:
Replacement Acer Aspire 5630 AC Adapter 90Watt 19V 4.74A
Replacement Acer Aspire 5630 AC Adapter 65Watt 19V 3.42A
Posted on Oct 26, 2012
  • Brandon Dean
    Brandon Dean Jan 26, 2013
    turned out that the charger was supplying a good 100 watts, so that wasn't an issue, but when I hooked it up to an oscilloscope, there was a LOT of interference, so I decided to bite the bullet and racked out 45 quid from Acer (UK) and it fixed the issue, plus they gave me a ferrite in case the unit had any interference, so it's a win win and the laptop's back to it's old self and working as reliably as the day I bought it, thanks 4 ur input as it has helped a ton!
Your f**ked
Posted on Oct 25, 2012
  • 193 Answers
SOURCE: Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Posted on Aug 14, 2009
Testimonial: "Confirmed my theory. ^_^"
SOURCE: Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Posted on Jul 10, 2008
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Posted on Feb 09, 2009
leecom72
  • 4806 Answers
SOURCE: my acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Posted on Aug 18, 2009
computus
  • 487 Answers
SOURCE: acer aspire 5516 battery and charger problem
Hi, this could be an unhelpfull suggestion but the charger may not be compatable with your laptop. Laptops notoriosly have different power settings, you may be forced to purchase a new Acer charger. Try ebay, you may be lucky
Posted on Aug 01, 2010
Acer Aspire 5315 charging circut fuse
So you have removed the battery from this laptop for at least 30secs - 1minute? Not really sure about a laptop fuse? Test your DC jack for continuity - with a volt meter - outside prong and inside stem. Those will be the first few steps to finding your issue.
Troubleshooting Laptop Adapter and DC Jack
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Jun 02, 2014 | Acer Aspire 5315 Notebook
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
Battery does not charge to my Acer Aspire 5738-6969
There is a known issue with the BIOS bug in some of the Acer model that it prevents charging. Trying upgrading the BIOS from Acer online to the latest version following the online instructions.
Sep 27, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I bought a new acer aspire 5630 laptp battery but it is not working when fits into, whereas when I put it on the old battery it works on the power as the old battery is fully exhausted. Someone told me to...
What I believe they were mentioning is Flash the BIOS to the most current version, which should on the Acer support site (Support.acer.com or such)
If the old battery wasn't charging and the new one doesn't either then there also may be a hardware issue with the charging circuit if the BIOS flash doesn't resolve, at which time you discuss that issue with Acer if under warranty.
Jun 23, 2011 | Acer Aspire 5630 Notebook
Charger is plugged in but not charging but can still power the laptop, how can i get the charger to charge the laptop
Same topic on hardwareanalysis.com:
AC adapter not charging Dell laptop battery, but still works?
http://www.hardwareanalysis.com/content/topic/75751/
Source for Acer Aspire 5520 AC Adapter
May 10, 2011 | Acer Aspire 5520-5908 Notebook
Acer Aspire 4520 laptop: Battery not charging
If your adapter /charger has low voltage it will not properly charge the battery, any battery. Go that route and try another adapter..
Sep 06, 2017 | Acer Aspire 4520-5582 Notebook
Acer laptop will not turn on
Don't think the memory upgrade would cause the power circuit to fault?
It might be your charger - in the transformer circuit block?
Hope this helps.
Oct 31, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
132 people viewed this question
Top Apevia Computers & Internet Experts
Paul Carew
Mohammed Ebrahim M
Mohammed Ebrahim M
Bill Boyd
Are you an Apevia Computer and Internet Expert? Answer questions, earn points and help others
