Question about HP Designjet T610 InkJet Printer
I try and load paper it shows its loading then it says feed paper so i do then it shows loading again. Then it shows paper not detected
SOURCE: Out of paper message shows for any paper I load
have had the same problem, cleaned rollers with a cotton bud
and nailpolish remover.
it actually works, for now anyway !!!!
Posted on Jun 09, 2008
SOURCE: Printer will not print
I had the same problem and to fix it there was a blue tray I had to pull out (the tray for the photopaper). Once it was pulled out so it was about flush with grey part beside it, the printer worked again. (The photopaper tray is just above where you put the regular paper.)
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: hp p1006 wont load/feed paper
i know this is not perfect but...
paper runs out during printing... so
1)open the front cover
2)close the front cover
3)IT WORKs
If i helped you please rate me
Posted on May 08, 2009
laxmankumar
  • 191 Answers
SOURCE: Error message request to load paper when paper is loaded. Appears that it doesn't detect paper or can't pick it up.
I recommend you to follow the instructions given in HP web-site only to ensure the proper functionality of your product.
Please Click Here and follow the instructions to check the functionality.
If problem still persists Click here and follow the instructions to clean paper rollers using Cleaning kit.
Posted on May 26, 2009
Tinteiros
  • 85 Answers
SOURCE: My D7460 will not feed paper The screen says load
Usually this occurs when a printer has had fairly excessive use. This causes the rubber paper feed rollers to become shiny and then they are unable to grab the paper, or it grabs several sheets at the same time. Newer laser printers have now have grooved belt tracks to help prevent this problem.
The easiest way I have found is to BUFF the shiny tracks... Here´s how... Using a ladies nail file (sand paper type) Press the paper feed button to cause the rollers to slowly rotate and buff the rubber as it turns. Making sure no sand enters the rollers. If several sheets of paper feed at the same time. Pull them out and a trick to stop this happening is... to fan the paper before loading into the paper tray. The trapped air will allow the sheets to glide easier.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Posted on Nov 02, 2009
My Polaroid z300 stopped printing pictures and keeps telling me to load it even though there's paper inside. How can I get it to print again?
It could be that the paper supply sensor isn't properly activated, or a new sheet isn't being picked up. Try removing all sheets of paper and inspecting with a flashlight.
I once assisted a frustrated elderly friend with a similar situation, and discovered that a white kleenex tissue had found its way into the paper loading mechanism! Her initial inspection had not detected it because it was camouflaged!
On another occasion, the rubber feed rollers didn't have enough friction to pick up a sheet of paper until they were cleaned with rubbing alcohol.
Dec 25, 2014 | Office Equipment & Supplies
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Paper won't feed. It's in the back stand up area
i have had this problem with a few Lexmarks. try a lighter weight paper or lessen how much your loading into it. also make sure nothing is in the bottom of where you load the paper (example: there is a pencil in there and the paper is sitting on the pencil) If its new take it back and exchange it. when it loads the paper the bottom of the tray tilts forward. that may be faulty.
Oct 21, 2009 | Lexmark Z1320 InkJet Printer
How to feed the paper??
hmmm,,,try clean the tray and then load the paper again or add the paper so the sensor can detect it easily..
if the problem still exist ..
try check the tray sensor.
May 12, 2009 | Canon PIXMA MP210 InkJet Printer
Model cf3102 display misfeed detected
We get a miss feed on our when we load too much paper. Try loading a little less. To undo a miss feed from overloading it you have to open and close all the drawers and eventually it will go away.
Jan 29, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Thick paper wont print
Per the user manual you should try using manual feed, loading one piece of paper at a time into the try and then following the on screen directions(whould be press the stop button once after paper loaded), find attached a image showing how to set up the manual feed0c16087.jpg
Oct 21, 2008 | Samsung CLP 300 Laser Printer
Paper Loading Problem
rollers can use a little cleaning sounds like..
Mar 23, 2008 | Lexmark X3350 All-In-One InkJet Printer
HP Designjet T610 InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
