Question about Belkin (F5D7230-4) Router (587009)
Belkin wireless router
Hey I want to lock my router but can't figure out how?? I tried typing my IP Address in the default web browser but had no luck?? Any help would be appreciated. Thanks
Belkin wireless router 802.11g
  • leelewis9 Jan 06, 2009
    The neighbor keeps using my wireless Belkin
  • Anonymous Jan 08, 2009
    I put in my IP adress and it will not work
  • 192 Answers
If you type the ip adress in your internet browser you would be sent to the sentings for your router. There sould be a secsion for wirless setings thats where you would secure it with a WEP password.
I hope this helps
Posted on Jan 05, 2009
Change my belkin router password want a diffrent password
Connect to the router via a cable.
Open CMD (command) prompt and type:
iconfig
you will see a default gateway listed - write the ip address down.
Open internet explorer and enter the gateway address into the address bar.
Should open a web page to configure the router.
You may have to provide a password.
If you're only interested in wireless password change, select different pages until you get to the wireless stuff.
Try this site:
http://techchannel.radioshack.com/change-security-settings-belkin-wireless-router-1402.html
How to Change Security Settings on Belkin Wireless Router
Feb 11, 2015 | Belkin Computers & Internet
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
I would like to install the belkin router without the cd the cd caused an error in widows and it locked up with a blue screen
Hello Kgmas,
You can setup the router simply by connecting to the router webpage. The default address should be 192.168.2.1; just connect to your router with an ethernet cable and then type the IP address into a web browser to access the page.
Once in the router web page you can set the administrative settings (password for the router) and you can set up your wireless network manually fairly easily.
Thanks,
Pat
Nov 07, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am attempting to lock my network connection.i have seen if you put the Ip address into the web browser it brings up instructions.each time i type in my ip address it asks for an username and password i...
Then google your router. if you had a belkin you would search for "belkin router setup"
this will tell you the default username and password, you can then set your wireless security password (choose WPA2)
If you cant find what you need, write back with your routers make and model
Aug 11, 2010 | Computers & Internet
How to remove pass code so wireless access is open not secured
1. Connect a computer to any of the four LAN ports of the Belkin Wireless router.
2. Open your web browser and type the router IP address of the router(by default, the address is (http://192.168.2.1) in the address bar press Enter.
3. Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit. If you have already changed the password then type in your password.
4. Click Security under Wireless menu.
5. Under Security Mode, select Disabled.
6. Click Apply changes to save the settings.
Feb 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
When I type in the ip address in my browser.....it doesn't open anything. it takes forever then eventually says error. PLEASE HELP!! Trying to find my WPA key so I can connect to XBOX Live. Been trying...
Which IP address are you typing in? The router will have a specific address. Its not your Internet IP address. Go to the Belkin website as the default IP should be th same for all belkin routers.
Jan 06, 2010 | Belkin (F5D8231-4) Wireless Router...
Wep
WEP
  1. Connect a computer to any one of the four LAN ports of the Belkin wireless router.
  2. Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
  5. Under Security, Select 64 bit WEP (or 128 bit WEP).
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you.
  7. Apply the settings. Please write down the key – You will need it later to configure your wireless computers with the same key.
Configuring WPA-PSK Encryption:
  5. Under Security Mode, select WPA/WPA2-personal (PSK)
  6. Select WPA2-PSK as your Authentication
  7. Select AES as the Encryption Technique.
  8. Enter a word or group of characters in the Password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
    Note: The PSK (Pre-Shared Key) is case sensitive ("A" is different than "a")
  9. Click Apply changes to save the settings
    Jun 04, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
    How do put the wireless mode on 802.11g mode instead of 802.11n draft mode, on my Belkin N1 Vision wireless router,F5D8232-4
    Open your web browser and type the router IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter, there should be an option there.
    Nov 25, 2008 | Belkin Computers & Internet
    Belkin (F5D7230-4) Router (587009) Logo
    176 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
