Question about Oregon 37-068 Pressure Washer Spray Gun With 12-Inch Lance Medium Duty 2,700 Max PSI 6.6 GPM 140-Degree F Max 1/4-Inch Male Inle
Karcher max 2700 psi 6.6 gpm 140F spray gun - Oregon 37-068 Pressure Washer Spray Gun With 12-Inch Lance Medium Duty 2,700 Max PSI 6.6 GPM 140-Degree F Max 1/4-Inch Male Inle
Is the craftsman gas powered 2700 psi pressure washer to strong to wash cars and trucks?
yes -- it will remove any loose paint then keep going to take all the paint off
if used around the mechanical bits ,it has the pressure to blow in gaskets and force water into places that water would not normally get to
Oct 19, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Pump builds pressure but not full pressure on same faucet iv always used
possibly have worn seals inspect them and also unloader valve which normally has a spring
Aug 13, 2014 | Craftsman 2700 Max Psi Pressure Washer 23...
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
2700 psi pressure washer oil capacity in pump
is there a nut with like a glass insert in it thats your oil leavel
Jul 13, 2011 | Karcher FactoryReconditioned 2000 PSI 20...
When i turn it on all it does is to keep surging
Check that you have sufficient inlet flow and pressure and that the inlet is not blocked in any way, both the supply hose and in the machine itself.
May 01, 2011 | Karcher Electric Cold Water Pressure...
Karcher Model K 2.40, water is leaking from the gun at yellow trigger.
You are going to have to purchase a new trigger gun, they don't offer any parts for replacement on the inside of this trigger gun. See this link to purchase a new one.
Oct 08, 2010 | Karcher FactoryReconditioned K240R 1400...
Oregon 37-068 Pressure Washer Spray Gun With 12-Inch Lance Medium Duty 2,700 Max PSI 6.6 GPM 140-Degree F Max 1/4-Inch Male Inle Logo
101 people viewed this question
Top Oregon Garden Experts
John Loiselle
Level 1 Expert
ray gallant
Ian Summerfield
Ian Summerfield
Are you an Oregon Garden Expert? Answer questions, earn points and help others
