Question about Bosch Nexxt Series Front Loader Washing Machine
My WAM1 bosch washing machine does not work. The power button pushes in but does nothing. I treied to unplug it over night & tried opening and closing the door several times. What can I do to try to fix this problem. thanks
ginko
  • 19396 Answers
SOURCE: door won't open Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
The door sensor/ lock is not working well
Posted on Mar 21, 2008
SOURCE: bosch Axxis problem
Thought these additional details might help as we are having a similar problem.
When the washer is turned on we get a blank screen, then after a bit we see the display flash. After sometime flashing then we see it go to normal and we can run it. It is as almost as if it need to warm up...
We can get the display to show faster, by playing with the knob. However, the machine still needs time before we can use it.
Any ideas?
Thanks in advance.
Posted on May 23, 2008
  • 135 Answers
SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
Posted on Nov 22, 2008
Macmarkus
  • 2605 Answers
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Dec 22, 2010
  • 414 Answers
SOURCE: washing machine bosch maxx 7 varioperfect
Sounds like have inadvertently activated the child lock. To deselect you need to press and hold the start button for approx 5 secs or until the key light goes out. Hope this helps, please let me know if this works or if you need further assistance.l
Posted on Nov 23, 2011
Fix f 37 beeper on Bosch wash machine
You could try unplugging the machine for an hour to try to reset it. The capacitors discharge & sometimes powering them up from empty resets things.
If that doesn't work you will probably need a new control board.?
That won't be cheap, so unless it's insured or under warranty, replacement of the machine might be the most cost-effective.?
Best of luck.
Mar 09, 2018 | Bosch Dishwashers
Bosch washing machine will not work after e2 reset
no lights? can you change settings? or just nothing when u push start button?
Jan 04, 2015 | Bosch Washing Machines
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Washing machine bosch maxx 7 varioperfect
Nov 23, 2011 | Bosch Washing Machines
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
My Bosch front end washing machine will not start a cycle. Door is closed tightly and when I push start/pause red light comes on & immediately goes off-this happens every time I push the start/pause...
My Bosch washer turns "on" and water runs but it does not spin or complete wash. I hear the machine "clicking" as if it is attempting to to function but no spin or full wash cycle.
Oct 17, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The door on my Bosch washing machine 1605 is stuck on shut
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Apr 21, 2010 | Washing Machines
Bosch Classixx will not start
Just a guess, but it sounds as if the machine doesn't think the door is shut. Try pushing against it as you turn it on, if that works, then I'd guess there's a door shut switch that needs adjusting.
NOTE. This reply is from an amateur guesser who knows nothing.
Mar 01, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Nexxt Series Front Loader Washing Machine Logo
35 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
