SOURCE: Grohe Ladylux slow to turn off
Your Grohe Ladylux should be under warranty. Call the company at 630-582-7711. Their customer service was great when they replaced my quick coupling after it broke.
Good luck
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
SOURCE: Water flow from grohe ladylux kitchen faucet has
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
SOURCE: grohe ladylux cafe kitchen faucet:
check and see if the weight is on the hose going to the handle, also check to see if the hose is free to fall down and that it is not hanging up on piping down under the sink
Best of Luck
Richard
