Question about Sewing Machines
I can't change to the type of stitch I want.....is there a reset button?????
Ex: from stitch 01 to stitch 07. The Panel in front doesn't recognize any changes I want to make. This is the first time this has happened.
  • Sewing Machines Master
  • 1,564 Answers
Try rebooting your sewing machine.
Posted on Nov 06, 2012
SOURCE: My new home sewing machine( model MX3123) won't go
sound like it needs to be serviced
Posted on Aug 03, 2011
Michaelle
  • 65 Answers
SOURCE: Don't know how to change the stitch length
I looked up the machine and found this threading diagram
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Here is a good place for other free solutions, as well as if you need parts for your vintage machine.
http://www.tandtrepair.com/Athena2000.html
Hope this helps!
Posted on Jan 24, 2009
  • 192 Answers
SOURCE: Husqvarna 955E will not change stitch length. Is
Does the length on the display change or is it as if the buttons are not even working. If the touch pad is malfunctioning you will probably find other buttons not working. Try all of the buttons and see if others do not work. If this is the case, the keypad can be replaced.
Posted on Sep 06, 2009
mizrach612
  • 102 Answers
SOURCE: I have a Hyundai 60 stitch sewing machine, the
Take the needle out and put it back in carefully. If that doesn't solve the prob, replace it with another needle, and hopefully it will return to working.
Posted on Sep 24, 2012
SOURCE: I'm getting skipped stitches on the right side of my button hole.
try changing the needle
Posted on Sep 25, 2012
There doesn't seem to be a stitch long enough on machine for basteing so I can gather material?
Try loosening both top and bottom tension. while longer stitches are easier, it can be done on shorter stitches as well. A bennifit to shorter stitches is the gathers will be smaller and easier to work with! Remember to reset the bobbin tension before sewing again.
Dec 16, 2012 | Janome 8080 Computerized Sewing Machine
The pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Oct 11, 2012 | Singer Featherweight II 117
I have a Hyundai 60 stitch sewing machine, the needle snapped so I replaced it now it won't stitch! I have changed bobbin, tension, tried different stitches but it still won't stitch! It's...
Sep 24, 2012 | Sewing Machines
Second Needle thread isn't stitching
change the second needle
rethread the second needle & every thread guide
see if that helps & if it doesn't then the machine needs to be checked
Aug 13, 2012 | PfaFF Sewing Machines
Stitch doesn't catch
have you tried changing the needle?
clean under the needle plate for lint or thread
May 07, 2012 | Brother PC-420
When trying to change to the other sewing stitches the cams will not the the selector pass
doesn't sound like he tried real hard, my suggestion is to find a sewing machine shop that will take the machine apart & find out why the selector doesn't move, it's possibly a worn or loose or broken part, & the repair man is suppose to open the machine & find out what's wrong.
Mar 01, 2012 | Bernina Sewing Machines
My top stitch is okay, however the stitiching on the bottom is wiggly, more like a zigzag stitch then a striaght stitch. Why?
try changing the needle--flat side to the back of machine
try adjusting the tension one number up--if it doesn't help put the tension back where it is
check to make sure the bobbin is in correctly
also check to make sure the bobbin is wound correctly
it's also possible that the machine is out of time which means a sewing machine repair shop would have to refix the timing of the machine, because they have the tools for the job
Jan 31, 2012 | Singer 7426 Mechanical Sewing Machine
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Came without an instruction manual
You should be able to buy an instruction manual from Janome or even on ebay.
Jan 21, 2008 | Janome D'cor Excel Pro 5124 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
