Question about Acer Aspire Computers & Internet
I have a acer aspire 4520 laptop every thing is working fine but one day i have a problem with the audio (red x mark on volume icon taskbar) i tried all the possible meathods to fix it like formating
ACER ASPIRE 4520 ,2BG RAM DDR2,NVIDIA CHIPSET DISPLAY AMD X64 DUAL PROCESSOR REALTEK HD AUDIO DEVICES PROBLEM (NO AUDIO OUTPUT DEVICE IS INSTALLED ) RED X ON VOLUME ICON ON TASKBAR
  • Acer Master
  • 2,878 Answers
Download driver. Unzip and run setup.
http://support.acer.com/product/default.aspx?modelId=14
Posted on Oct 25, 2012
bijoybakal
  • 57 Answers
SOURCE: blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Posted on Jan 01, 2008
  • 10 Answers
SOURCE: how do i install audio output device
No Audio Output Device Installed
Some users have been experiencing problems with a "No Audio Output Device Installed" error when trying to play music, or when hovering the mouse over the speaker icon in the system tray. You may get a white X in a red circle to indicate this error.
Go to the device manager by pressing WINDOWS KEY + R to go to the run menu, and then run "devmgmt.msc".
From here, select your malfunctioning audio device(s) and make a note of the driver name. Then, right click on it and select Uninstall. This will remove the audio drivers from your system.
Once this is done, re-load the drivers for your sound card from the CD your manufacturer gave you with your PC or sound device. If you cannot find this, search for the driver on the manufacturers website using the driver name that has been written down. No Audio Output Device Installed
Posted on Aug 27, 2008
SOURCE: acer aspire 5520
necesito la tarjeta de video para mi portatil ECER por favor ke alquien me ayude :(
Posted on Nov 10, 2008
1234s282
  • 144 Answers
SOURCE: Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Posted on Jan 24, 2009
bobyi
  • 32 Answers
SOURCE: No Sound from Acer 5100 : Volume tab is disabled
Acer Aspire 5100 PC Notebook main problem is Connection Problem, Software Problem etc.
For these problem you can visit a link by just Click Here .
For any other problem with this Notebook you can Click Here
Posted on Jul 20, 2010
Hi , Im trying to make my external volume controler work om my Aer 4520. Its a litlle ring that puts volume up and donwn
Ebv65,
External speakers for your laptop are very easy to hook up. They should plug right in to the external speaker outlet on the laptop. Your acer 4520 has a Headphone/speaker/line-out jack with S/PDIF support. First you need to check all your volume levels within the control panel (located in the sounds and devices folder) to make sure they are up. This solve your problem. Thanks for visiting Fixya.com. Have a great day.
techguy21
May 28, 2011 | Acer Aspire 4520-5582 Notebook
My audio device is installed but it shows that no audio device is installed.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 28, 2011 | Acer Aspire 4520-5582 Notebook
My sound on my acer aspire 5516 works fine until i put in a dvd then the sound will not work how do i turn it on ?
Double click the "speaker icon" on the right bottom bar to open the
volume control menu.
Check be sure that the check box "mute all" on the bottom of volume control
is not checked.
On an "Acer Notebook" try to press following keys combination: FN+F8
FN+ F8 : turn on / of speaker.
FN + > to increase the volume.
Good look
Feb 19, 2011 | Acer Aspire 4520-5582 Notebook
How to install volume icon in taskbar
For Windows XP, click on Start, Setting, Control Panel. Double click on Sounds and Audio Devices. Check the check box that says place volume icon in the taskbar under the Valume tab.
Dec 20, 2010 | Acer Aspire 3000 Notebook
My acer 4520 laptop speaker is not working.
download and install latest rettlrtek audio drivar
Dec 13, 2010 | Acer Aspire 4520-5141 Notebook
My webcam dosen't work for video chatting, sometimes when i want to use webcam, it say CREATION OF THE VIDEO PREVIEW FAILED. PLEASE CHECK THE DEVICE CONNECTION AND MAKE SURE THE DEVICE IS NOT BEING USED BY...
Please find the below steps to access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Suyin) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Sep 22, 2009 | Acer Aspire 4520-5582 Notebook
Audio Not Working!
just check the volume control some programs mute it for some reason go to all programs on your start panel>accessories>entertainment>volume control hope this helps regards Jim
May 01, 2009 | Acer Aspire 4520-5582 Notebook
Acer 4520 Booting Problem.
i would suggest to uninstall and reinstall the drivers of your network adapter, or it would be best if you install the latest drivers for it. no need to format the HD.
if you feel that formating is needed, it would also work but that takes a lot of work.
hope this helps. :)
Oct 05, 2008 | Acer Aspire 4520-5582 Notebook
ACER ASPIRE 3000
Left click the volume icon in the system tray in windows.
A slider will appear which you can drag up and down to change the volume on the computer.
If the volume icon is not in the system tray, do this:
Go to Start->Control Panel
Pick Sounds and Audio Devices
Open the Volume tab
Tick "Place volume icon in taskbar"
Now you should have an icon in the taskbar.
If you cannot do this, then you do not have the proper sound card drivers installed and you computer will be playing no sound whatsoever, which is unrelated to your question.
Jan 25, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
