Question about Lexmark X4650 InkJet Printer
Failure to install X4650
X4650 successfully installs on an XP operating system but fails to print any documents. Error message says that commuication is non existant. USB being used not wireless. Any ideas?
  • bfsm Jan 29, 2009
    Did this may times without success. Thanks for the response.
  • markshep77 Feb 04, 2009
    I have a windows XP machine installed the driver and plugged in the printer when requested, it does not print out at all. All other functions (Scan etc) work. I have removed the driver and reinstalled... Same issue, tried the downloaded driver and again it will not work. Tried it on my laptop with Vista and it worked fine, so I know the printer is not at fault. Please Help.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
My lexmark x4650 wont print pdf files
Make sure that your printer driver is updated. Please visit the Lexmark website to download and install the Lexmark X4650 printer driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the installation process is successful, try to print your PDF file again to verify that the problem is fixed.
Also, make sure that your adobe acrobat reader is updated.
Nov 03, 2011 | Lexmark X4650 InkJet Printer
After scan, whatever save function is used the error message "printing application has stopped working" appears with the only option Close Application.
Try to re-install the Lexmark X4650 driver. Visit the Lexmark website at http://bit.ly/iofMNC. Select your operating system, download the driver and execute the file.
Jun 18, 2011 | Lexmark X4650 InkJet Printer
Service 960 memory error- r for my Lexmark C532n printer
A 960 RAM MEMORY FAILURE message indicates a failure of the RAM MEMORY that is soldered onto the printer's main controller/system board.
If the printer is displaying a 960 memory error.
1. Power off the printer.
2. If you have any extra memory SIMMs or code SIMMs installed in the printer, remove them.
3. Power on the printer.
4. If the 960 error continues, the main controller/system board will probably need to be replaced.
5. If the 960 error does not return, try printing a few documents.
6. If these documents print correctly, the cause of the 960 memory error is probably one of the SIMMs you just removed.
To confirm this, do the following:
1. Turn off the printer and reinstall each SIMM one at a time.
2. After you install each memory card, power the printer back on and try printing. If the error returns as soon as you install a particular SIMM, that SIMM is probably the cause of the error message.
Nov 08, 2010 | Lexmark C530dn Laser Printer
Odd application failure... missing assembly?
Mark,
Do you have the Visual C++ 2005 Redistributable installed? The "Dependent Assembly..." error indicates that you do not have it installed yet. You can download it at the link below. Please report back with your results.
http://www.microsoft.com/downloads/details.aspx?familyid=200b2fd9-ae1a-4a14-984d-389c36f85647&displaylang=en
Ryan
Mar 23, 2009 | Microsoft Windows XP Home Edition
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
Sep 16, 2008 | Office Equipment & Supplies
Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Lexmark X4650 InkJet Printer Logo
153 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
