Question about Campbell Hausfeld Pressure Washer. 1850 psi 1.35 GPM Lavor Pump
Instruction Manual for LAVOR pressure washer eq-18
I have lost pressure on my Lavor pressure washer
Oil seals are needed for sure. But you also need to check the valves! To check them, remove the valves, clean them and check them! You can check them to see if they are working properly by put the valve to your lips with them metal side or the bottom to your lips then blowing, if they "flutter" good then try to suck air through them! If you cannot suck air, they are good! Then inspect your water seals. They tend to dry out and weaken when used all the time.If they look worn, then replace them making sure you put the new ones back Exactly like the old ones came out! You should be good then! If not, check all components out side of the pump mainly the Unloader (regulator). Best of luck to ya!
Sep 23, 2014 | Garden
Lavor superwash 160 exploded diagrams
try e spares on the internet they may help
Jan 17, 2014 | Kitchen Ranges
Weak pressure
seals may be worn although a high speed pump is not normally recommended for siphoning due to pump rotating at an rpm as fast as the motor belt drive gear drive or slower rpm pumps will siphon much better.
Dec 30, 2013 | Garden
Lavor thermic 3/s
remove the spark plug and see if the cylinder if full of gas if so replace the needle and seat in the carb
Aug 09, 2012 | Garden
Hi, I try to connect the Kenwood EQ to my Marantz SR-18, where is exactly RCR jack should I connect?
you want the audio signal to go to eq input then out of eq into rec input of your choice
Jun 05, 2011 | Marantz SR-18EX Receiver
Lavor Super wash Powerwasher.Lidl. Pressure leak O ring replaced at Venturi & wrote down wiring diagram for On/Off switch as follows- Blue Red Brown, Black. Had to disconnect wiring from On/Off...
hi i have a lavor 160 superwash all off the lances work except when i put the turbo lance on it gives high pressure and then goes to low pressure like starting then stopping can anyone help me or tell me what the problem may be
Feb 28, 2011 | Kitchen Ranges
What type of oil do I use for the 2550PSI pressure washer engine and how do I change the oil completely?
To empty the oil you tip it over on it's side. The type of oil to use is car oil and depends on the temperature where you live. The manual is available at http://staging.us.kohler.spectracom.com/pdf/owners_manual/101%5C020273_0_om-Domestic.pdf and on page 18 it tells you the type of oil for different temperatures.
Jan 09, 2011 | Briggs Stratton 020273 Elite Series...
Hi I have been given a telescope but no assembly instructions and the only markings on it are "Atlas Explorer" & "D=60MM F=900MM Coated Optics Made in China" Would you know where I...
That is NOT an Atlas EQ-G as your question indicates -- this is an atlas eq-g-
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-atlas-eq-g-computerized-goto-telescope-mount
This is a 60mm refractor style telescope imported from China. No one will have a manual for that scope. Try to locate a local Astronomy club and the members will help you assemble it.
Nov 20, 2010 | Orion Atlas 8 EQ-G Telescope
Where can I get a manual or instructions for the Orion SpaceProbe 3 EQ
Contact Orion directly here:
http://www.telescope.com/control/main/
and here is the manual directly off their web site shown above:
http://content.telescope.com/rsc/img/catalog/product/instructions/IN_208_SpaceProbe3_EQ_B.pdf
Sep 13, 2010 | Orion SpaceProbe 3 EQ Telescope
Campbell Hausfeld Pressure Washer. 1850 psi 1.35 GPM Lavor Pump Logo
262 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
