Question about Uniden DECT 6.0 Cordless Phone ID
How do I remove messages from my uniden phone
I have listened to the message but the screen still shows 1 MSG how do I delete it or send me the manual I can't find mine
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Oct 25, 2012
  • 13 Answers
SOURCE: Uniden cordless phone....mod. # TRU 9280-2
The delete button is the one with the circle with a slash through it.  I checked the user manual online, and it should be the bottom right button out the 8 round buttons on the base (just to the right of the next button, right under "find hs").  Hope this helps!
Posted on Dec 25, 2007
SOURCE: voice mail notifier on a Uniden DECT 6.0
press and hold down [find hs] on the base for five seconds
Posted on Feb 20, 2008
SOURCE: uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Posted on May 29, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
  • 3 Answers
SOURCE: cant register/install a new dect 6.0 uniden 2060 phone
I had a similar problem which I finally fixed. You did not say if any of your phones registered.
First try the following recommended by Uniden Support:
Your phone(s) should be fully charged before putting them on the main base.
Unplug the battery from the phone by removing the battery cover and removing the connector. Then, push the # and * key together and hold while you plug the battery back in (requires some dexterity). Continue to hold the two keys until you hear a confirmation tone. This will force the phone to reregister. Put the phone on the main base (if you are sure it has a fully charged battery) and see if it will reregister it to solve the problem.
That did not work for me. So, I followed the instructions to de-register the handset (even though it hadn't really registered). But, I also pretended like the Base was not available (because using the base in this step also failed).
1) Press and hold the hang up and # keys for at least 5 seconds.
2) Move the cursor to select Base Unavailable and then press Select.
3) Select the base you want to deregister from, press Select and then move the cursor to Yes and select.
This causes the phone to delete any of its base information.
At this point, again insure that your phone shows the battery is fully charged and if it is not, put it on the stand alone charger base (not the main base). With the battery fully charged, place it on the base and try registering again by placing it in the main base.
If neither of these approaches help, contact support at Uniden.com.
However, my problems were cleared when I cleared the handset with the second set of instructions.
Posted on Apr 26, 2009
How to delete voicemail
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
How do I listen to and erase message?
Are you trying to get the messages from the phone directly or by calling into your phone.
If the answering system is on, then you can play back the messages from the base by pressing the Play/Stop button.To delete a message from the base, press the Delete button (has a 0 with a slash through it) while the message is playing. To delete all messages, press the Delete button when the phone is in standby. From the handset press the Messages softkey (has an envelope icon) when the phone is in standby. Then press Play/2 to play back the messages. To delete a message, press Delete/4 while it is playing. (Deleting all messages can only be done at the base.)
If you are calling into your phone system, you need to have set a two-digit PIN from either the base or the handset and remember it. Then call the number for your phone from a touch tone phone, press 0 and then the PIN within 2 seconds. (Do this while your greeting is playing or after a series of beeps when the phone answers your call after 10 rings if the answering system was off.) If the system is off, start by pressing 0 6 to turn it on. Press 0 2 to play back the messages. (All commands need to be entered within 15 seconds of the last command finishing with both keys pressed within 2 seconds.) To delete a message, press 0 4.
Uniden has the manuals for most of their phones on their support site: http://www.uniden.com/scat/cordlessphones_mnl . Phones are listed in numerical and alphabetical order; thus the TRU9480 manual is on page 7. The direct link to the TRU9480 is http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/TRU9480om.pdf .
I hope this helps.
Sep 01, 2011 | Uniden TRU9480 Cordless Phone
We've listened to all of our messages and deleted them. However, the red light will not go off on our Avaya 5410 phone. How do we get this red light to go off?
Look in teh "Manager" program. look unders users, than select that user. Go to the "trusted source" tab. Is there a number with an "H" in front of it? (H200 for example)
If so, that phone is lighting up when there is a message in teh hunt group mailbox.
Feb 10, 2011 | Avaya 5400 Series 5410 Phone
My nokia N72 showing in the screen ''massaging not enough memory to perform operation.delete some data first'' when i want to write msg.
sir delete the inbox,sent message,outbox,draft,messages to get the enough memory from the phone and then you can send the message...........
Nov 22, 2010 | Nokia N72 Cellular Phone
I have a message in my outbox
Try this but you have to use the LG PC Suite.
Reset the Handset reserved memory by:
1. Go to "Setting" then "Memory Manager" then choose "Handset Reserved Memory "
2. Choose "Clear All" then choose "Yes"
3. After this an envelope will appear on top of your screen
4. Use the PC Suite on your computer choose "Message" then "SMS" then "Task" then"Reload" then choose "Outbox" from there delete the message.
Jul 08, 2009 | LG KF310 Cellular Phone
Dialing in to get Voice Messages.
After the answering machine beeps for you to leave a msg - enter the 3-digit security code. If you haven't already set that function up, the default is 1-2-3.
Once in, use these buttons for:
#1 - Review msg
#2 - Play back msg
#2 again to Stop the play back
or #0 to delete during play back
#3 - Skip
#4 - Turn off/on answer
#7 Review voice menu options
Mar 26, 2009 | Uniden Cordless Phone
Do not know how to delete voice messages from my sagem phonefax 320. In box is full
Deleting a Selected Message:
Individually, while listening to it, you can delete a message that has not been totally listened to.
  •  Press the C key, then OK during the message you want to delete.
  • Delete received messages by pressing 1 then 5
  • M 44 OK DELETE MSG Delete the voice messages.
http://support.sagem-communication.com/site/livret/lu_phonefax_2320_25_12_2410_20_25en.pdf
Here is what you need!!! Click on the Above Link. Download the User Manual!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Feb 28, 2009 | Sakar Talking Caller-ID Speaker Phone
Unable to send text messages on my new nokia 5800
All you have to do is go to your message setting on your phone:
1. Open Messaging
2. On New message sellect options at bottom
3. Open settings
4. Open Text message, you should see: Message centre, message centre in use ect..
5. Open message centres this should go to next screen then open again, this screen should have : Message centre name & Message centre number (from your network provider you need to find out what is the message centres name & number are e.g in Australia it should be SMSC1 and number is +61411990001) then just manually enter these in there.
Feb 26, 2009 | Nokia 5800 XpressMusic Smartphone
Msgs - Too many msgs!!!!
SMS and picture messages are not stored on the memory stick.
Sony Ericsson phones have a set allotted memory space for messages and other phone functions.
You may need to delete picture messages, check if you have any saved messages (these are saved to your SIM).
Generally, the only other option would be to reset your phone.
To do a master reset, go to your Menu, then select Settings. Under the General tab, scroll down to Master reset and press select. Select Reset All and press yes.
If prompted, the default passcode is 0000.
Please note that a Master Reset will return the phone to its factory default settings (including locking a phone to the carrier if it has been unlocked). All user data and settings will be deleted. If you have any files or information you would like to save, you should either back it up to a memory stick or your computer. Your contacts can be backed up to the memory stick or your SIM card.
Mar 05, 2008 | Sony Ericsson K800i Cellular Phone
Problem sending msgs
Uniden DECT 6.0 Cordless Phone ID Logo
59 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
