Question about Samsung SM-DV209AGW - SERVICE MANUAL
Samsung dryer stops working mid cycle. Display goes blank. No codes.
My Samsung dryer (model DV209AEW) stops working mid cycle. When it stops, the power goes dead (no light on inside; can't press start to restart, etc.) and therefore no code is displayed. After several minutes, the unit will beep and the display will come back on and be flashing the remaining number of minutes left in the cycle. The unit does tumble when it runs and produces heat. I have cleaned the lint filter and vacuumed the filter area and the unplugged the vent and vacuumed the vent with no success.
IB4G2008
  • 3587 Answers
SOURCE: stops mid cycle
that's the washing machine version of going on a walkabout, no? just kidding.
E9 suggests that the line is getting clogged. the filter pulls out(see user manual for that option) and you might want to consider running it with baking soda solution in warm water or hot, once or twice to get rid of that odor.
Posted on Mar 11, 2008
appldoctom
  • 311 Answers
SOURCE: Hi... My washing machine... samsung
nf is the failure code for [no fill].check your water valve screens for a mineral buildup/blockage.they are where the fill hoses attach to your washer.make sure water is present at washer[run the water from each hose into a bucket].i live in ohio its 0 degrees out side now.i did't know it but there was an air leak near my dishwasher drain hose in the house and water froze in it blocking the drain.i hope this info helps you fix this washer, God bless ,tom
Posted on Jan 16, 2009
SOURCE: samsung silvercare washer stopped working, won't unlock
here is the most common cause for this problem, according to the Samsung repair guy that was here to fix mine today.
On these washing machines it is possible for some debris (in my case it was a small screw from my packet) to make its way passed the drum and into the pump. Once this happens then the impeller of the pump becomes restricted or completely blocked which will result in the above mentione symptoms.
On some machines the pump is on the front, on others at the rear of the machine. In my case it was at the rear, removing the rear panel will allow easy access to it. Have a bucket ready, when the hose is removed from the pump the water will be draining from the machine. 3 bolts and a hose clamp on the inlet and another on the outlet hose. Disconnect the electrical plug from the pump and you can remove it from the machine for cleaning. A very easy job, requiring little skills and not much in terms of tools. (make sure machine is UNPLUGGED from AC outlet)
Remove obstruction(s) from pump and reinstall in reverse order of disassembly. The guy says these pumps are really tough so if you hear it buzzing, trying to go while it's jammed it's a good sign it will work. If not, replacement will be necessary.
Cost me $140. Could have been worse I suppose. Advise: Empty pockets BEFORE washing clothes...
Posted on May 26, 2009
  • 1684 Answers
SOURCE: No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
milten1
  • 1304 Answers
SOURCE: Washer stops with "nf" displayed on screen
nf is no fill
with samsungs most of the time its a bad resistopr on the cold water vale itself,
check your screens though
Posted on Oct 03, 2009
I own a Samsung dryer model DV218AEB/XAA. In both the sensor and timed cycles it shuts off early and goes dead for about 30 minutes before it comes back to life and the load can be restarted, only to
I have a good idea that it may be the following;
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
You can check out other possibilities and order parts here using the following link;
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/2---/Dryer-stops-turning-during-cycle
Good Luck!
Rich Lilja
Oct 29, 2014 | Samsung DV218AEB/XAA 7.3-CuFt Electric...
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
We have a Samsung front loader. Model # WF328AAIWIXAA. We started the machine to do a load, and later we were going to transfer the clothes to the dryer. It appears to not be getting power. We cant open...
Is the display (User interface) is lighting up and on. That means you are getting power.
If display on and cycle stopping at mid cycle and cannot open door.
If the machine water level sensor detects sufficient water in the machine it will tell the control board not to release the door.
Is there is water in the machine. May be your drain pump is clogged. Does it give a error code on display.
Don't force open the door. You will break the lock and you will need $ 200/= parts and labor to change the door lock
Call a local service guy
Oct 25, 2017 | Samsung WF337AAL Front Load Washer
I have a Samsung dryer model # DV209AEW , approx 1 yr old , The dryer quit working on the sensor mode (it would keep adding time to the cycle) so we started drying on the timed mode , today it will not...
The belt slipped off the pulley. There is a switch to keep the drum form starting if there is no tension on the belt. There is a service bulletin on most samsung dryers to install a bigger motor pulley to keep the belt from slipping off. Contact your local samsung service provider, or samsung directly and they should take care of it for you.
Jan 30, 2011 | Samsung Dryers
My Samsung DV209AEW dryer has stopped working, All the lights continue to come on and the main panel will state cycle drying but is is not. I have cleaned all the vents and the hose to no avail.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
o
Sep 30, 2010 | Samsung Dryers
Dryer just stopped working in mid cycle.
Verify there is still power at the wall and check the thermal fuse.
Eric
Jul 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer stops in mid cycle and gives me an error code of E1
It is a bad thermistor on the blower housing
http://forum.appliancepartspros.com/dryer-repair/1379-kenmore-elite-e1-sensor.html
Apr 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Samsung SM-DV209AGW - SERVICE MANUAL Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
