Question about American Audio DP2 Professional DJ MIDI Controller with Soundcard
How to hook up the dp2 midi controller to my laptop
Can not hook up
I Am Trying To Hook My Behringer X2222USB To My DAW How?
Once connected to the computer you have to open your Daw and find the menu to activate the mixer via midi. Check the user manual of your Daw. Also you might have to do some midi mapping to set up the controls.
Apr 09, 2016 | Behringer Music
How do i hook up a midi instrument
Make sure the driver is there first, if not download the driver. Then goto system prefs and click on audio. In there select the driver and that should do it.
Oct 15, 2014 | Computers & Internet
How do I edit the midi preset parameters on a behringer gmx212 using a laptop?
by using a midi editor, midi data cannot be changed while traveling through the cable there are 127 different options for midi, and it needs a digital platform to funtion correctly for paramaters.
Aug 01, 2014 | Behringer V Tone GMX212 2X60 Watt Stereo...
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I just got my first MP can i use my mac ibook that i have a program call Reaper. i know i have to have scsi but can use a midi to do the same??? thanx
Your Mac should detect your MIDI keyboard automatically. To make sure of this, open "Audio MIDI Setup" and click "Show MIDI Window" in the "Window" menu. In that window you should see your Akai listed as one of the MIDI devices.
Now, open Reaper and open "Preferences". Find the "MIDI Devices" section on the left side and make sure the Akai is listed on the right side. Then make sure that inputs and outputs are enabled.
Once that is done, Reaper will allow your Akai as recording input on any track.
Check the Reaper manual for more specifics on recording in Reaper.
Feb 19, 2011 | Akai LPK25 Laptop Keyboard Controller (...
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Getting midi to register
Your question is very confusing. Try rephrasing it. You should try drawing a diagram with this and uploading it to your question to better explain yourself. If you can't upload it (I know I can through the answer, but I'm not so sure about the question) you can e-mail it to me. My address is johnkennick@yahoo.com , if not just put some more detail into the question and try rephrasing it. I'm not really sure about the details of your system.
Mar 12, 2008 | Tascam US-122 USB Audio/MIDI Interface...
MIDI hookup
The midi port looks like the bottom one in the picture:
http://www.e-tech.nu/images/sound_connectors.jpg
You need a cable from the keyboard midi (din connector) to the DB-15 on the sound card/mainboard. If you dont have a 15 pin midi/game connector you could buy a soundcard with midi onboard or a usb midi port like the:
http://www.zzounds.com/cat--USB-MIDI-Interfaces--2434
Jan 11, 2008 | Car Audio & Video
American Audio DP2 Professional DJ MIDI Controller with Soundcard Logo
20 people viewed this question
Top American Audio Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you an American Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
