Question about Moose Z234 8 Zone Expander Z1100 Z1100e Control Panel
We bought a house with a moose alarm system and we are not using it, how do we remove it?
Drains battery
my aftermarket alarm used to drain my battery. fixed it by removing alarm system.
Oct 10, 2013 | C3 RS6652W (NEW with 1 LCD Transmitters)...
Keyless pad entry
That is a old Moose. I would not install it but if you must, check out ebay.
Sep 05, 2013 | Moose Mpi-775 Burglar Control Panel Keypad
How to reset master code on adt alarm system without original master code
try 1234,just for kicks and giggles. if that does not work, I need to know system type.
Dec 01, 2012 | Home Security
I have a moose z1100e and after a power outage i cant get in to program, what do i need to do?
It has been my experience that if an alarm panel behaves differently after a storm or power outage I would power system down wait 1 min power back up. If that does not help. Then I would try to default the panel and reprogram it, if the customer was desperate to keep it. If not(taps plays in backround) time to replace panel.
http://sirflannel.homeip.net/files/security/Burg/GE/MooseZ1100E-installation.pdf
GL
Aug 04, 2011 | Moose Z1100r Z1100 Led Control Station In...
I have a DSC PTD1640u and it keeps "chirping" every minute or so. I do not know how to make it stop. It came with the house I bought, so I do not have any codes or the manual for it. Please...
The DSC PTD1640U is a power supply for a DSC alarm system. Is the power supply (wall transformer) actually chirping or is it the alarm panel? If its the wall transformer, jsut replace it. If it's the alarm panel, what you need to do is find the type of alarm panel you have. It's usually on the circuit board or panel cover. Then download a user manual for that panel, just google it. Then follow the instructions to reset it or remove the alarm fault.
Jan 13, 2011 | Computers & Internet
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
Sep 22, 2010 | Honeywell 5804 Ademco Wireless Security...
Removed alarm system; now phone won't work
In the alarm system there was a jack called an RJ31X. This jack is suposed to have the line run from the teleco interface to it and then back out to the rest of the house(except for DSL, it stays ir front of the alarm jack). When the alarm jack was cut out the line bridge was eliminated. To make the line active find the wire that went to the alarm jack and and connect the red wire to the yellow wire and the green wire to the black wire. that should pass the line through to the remainder of the jacks in the house.
Oct 13, 2009 | Lands Phones
How to reset the safe house alarm very old style model # 49-470A
i bought house alarm second hand and it has reset it self to factory setting 1234 but on pad its say called engineer to reset can you help
Jun 21, 2009 | Home Security
Moose Z234 8 Zone Expander Z1100 Z1100e Control Panel Logo
23 people viewed this question
Top Moose Home Security Experts
Lawrence Oravetz
Are you a Moose Home Security Expert? Answer questions, earn points and help others
