Question about AVer Kandi 150Cc Go Kart Kd-150Fs: Toys & Games
How to hook up ignition on a kandi gk 250 go kart
I have a gk250 go kart have a problem somewhere with the wiring it will not start on the ignition, I have to start it by crossing out the top bolts on the relay. But when it is running I can shut it off using the key.thought it was the ignition and replaced it but still same problem, but not sure if it is hooked up right. Can someone please help me
Charge battery starts ok but next day battery is dead
The ignition switch is bad or a wire has been scraped and is shorting out somewhere. Double check your light panel chassis and other positive-connecting wires to make sure one hasn't crossed over during battery replacement or other maintenance. A loose or partially exposed wire will cause this. If you've owned it for a while or bought it used, look for wear around the key hole or rust on the back of the ignition switch. Hope this helps.
Feb 09, 2016 | Garden
Should the two radio speakers turn on when the key is turned to start my 1984 kawasaki zn1300?
Check the wiring to the ignition and radio to make sure none of it crosses the ignition or radio some models require the positive to connect to the ignition but only in the on or run position but it could be a simple wire ground out someplace
Mar 24, 2014 | Radio Communications
Replaced transformer
This go cart does not have reverse, so positive & negative wires must be switched.
Dec 01, 2013 | Razor 300001-SL Ground Force Go Kart
77 gs 750 wont start
on the starter relay cross the 2 bolts to see if this starts the bike with ignition on. presuming it has electric start
Mar 10, 2013 | Motorcycles
I just replaced the starter on my 2000 Bravada. No other problems before starter replacement. Can someone please tell me why, now, when I am hooking up the battery, the truck is trying to turn over...
Because the ignition switch wire (small purple wire) or connector is touching the hot post on the starter.So when you connect the battery it just like turning the ignition key to start the engine. Make sure all the wires on the starter are not touching each other.
Aug 10, 2011 | 2000 Oldsmobile Bravada
I'm looking for a wiring diagram for a carter go kart.it has only four wires to the ignition switch but they were burned when i bought it.The wires ars red white green and black
I have some wiring diagrams for a few go-karts on my site. http://gokartbazaar.forumotion.com they are in the troubleshooting section.
Sep 21, 2010 | 1981 Suzuki TS 185
How do u change the spark plugs on a 1994 toyota camry
Start with a cool/cold engine.
Four cylinder: Remove spark plug wire boots (four in a row on top of the engine). DO NOT PULL ON THE WIRE only the rubber top. Make sure the wires are numbered, if not, number them. They MUST go back to the same hole they came out of after the new plugs are installed. Remove the spark plugs with a 16mm spark plug wrench. Install new plugs (any auto parts store can tell you what your options are here): Start threading the new plugs by hand so you don't cross thread the engine head by accident. Then complete tightening them gently. Spark plugs are supposed to be tightened to a specific torque: 13ftlbs in this case. If you choose to not use a torque wrench do not overtighten the plugs. Reinstall boots securely.
6-Cylinder: Remove engine cover, if present. Disconnect the six connectors on each of the ignition coils. Remove each of the six ignition coil bolts and then remove the coils by pulling straight up -- arrange them so that you know which goes back where. Remove and install the six plugs as described above. Reinstall the ignition coils with their bolts (torque: 69 in-lbs), then wires. Replace the cover.
Jun 11, 2010 | 1994 Toyota Camry
96 ford explorer wont start. all power when turn key. nothing.
if it turns over from below,then its in the ignition switch and this also feeds power to the e.c.m. to make the engine fire so you either have a bad switch contact or the hot 12 volt wire to the ignition switch
Mar 20, 2010 | 1996 Ford Explorer
When starting the car...trunk opens..when turning off ignition alarm arms and goes off if you don't have the door open...after driving for a time car stalls
has the dash been pulled apart? any reason why there would be wires crossed? i have heard of someone having their trunk pop when starting their car, but they put the dash from an mk4 in their mk3, and crossed a couple wires. as far as the stalling, it is most likely because your alarm is going off. your best bet, is to take it to a mechanic, unless you are good with wiring, and either have them rewire the alarm, because somewhere there is a loose connection, and it's tripping itself, or have them snip the alarm all together.
Jul 28, 2009 | 1996 Volkswagen Jetta
AVer Kandi 150Cc Go Kart Kd-150Fs: Toys & Games Logo
128 people viewed this question
Top AVer Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an AVer Office Equipment and Supply Expert? Answer questions, earn points and help others
