Question about Steamist Steam Bath 4.5/6 KW Unit SM46
Steamist 46 generator does not produce steam; leaks water
Unit is about 6 yrs. old. After 10 minutes, unit is not producing steam. We turn unit off, and water pours out the safety valve, flooding the floor. What is the problem? We have 2 units--one in each bathroom--both are doing the same thing. SHould the unit produce steam in 10 minutes?
3 Suggested Answers
GeneratorDan
  • 44 Answers
SOURCE: My SM11 model Steamist was
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Posted on Nov 06, 2010
SOURCE: SM-79 turns on normally and
Hi Russell.
I am going to suggest contacting Steamist since they are the experts in this product.
http://www.steamist.com/contact.htm
My understanding is Steamist has 5 year parts warranty, and 3 year labor warranty, which is good warranty.
It seems you have passed the warranty period, and 16 years is a good run for any type device.
The contact e-mails includes 'literature' so you can order a manual, 'troubleshoot' so can get directions from the folks who make the product, and email for sales manager.
I would also inquire about authorized service center, and ask what is likelihood of getting long-term repair vrs buying another unit.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 11, 2011
I have a steamist lt90 that we recently installed. It stays on for about 5 minutes then trips the breaker. It was installed using #10 wire and a 30 am breaker. Any ideas?
!!!!!First look on data plate see what is the rated amperes and kW . Make sure what code is for steam generators.
Some steam generators do not recommend GFI circuits to avoid nuisance tripping.
If you can us GFI in circuit breaker you may need two hots a ground and a neutral.
As a rule
30 amps = #10 wire
40amps = #8 wire and
50amps = # 6.
Generators normally are 240vts the two hot wires connect to # 1 and #2 wires coming from unit.
Aug 26, 2015 | Dryers
Lg steam washer 2yo 3 yrs old . Refresh cycle produces bribble of water rather than steam and leaves clothes wet
The steamer unit may be overfilling. Check the water valve and see if it leaking. If it's ok, you will need to replace the steamer unit. Good luck
Jun 17, 2011 | LG F1402FDS6 Front Load Washer
SM-79 turns on normally and operates for about 5 minutes. Enclosure temperature goes up to about 79 degrees and the unit turns off. Very hot water issues from outlet until thermostat is turned off. ...
Hi Russell.
Feb 11, 2011 | Steamist SM-79 7900
What size breaker does the sm-11 require 2-30amp or 2-60 amp?
You will need the 2-60A breakers. 11kw is 11,000 watts. Watts = voltage X Current (amperes) If we take this formula and change it around to calculate amperes it is like this. Amperes = watts / volts amperes = 11000 watts / 240 volts This is 45.8 amperes or let us say 46 amperes. The closest breaker that you have would be a 50 amp breaker 2 pole of course . 2 - 50. If you cannot get a 2 - 50 then a 2-60 is fine. I would run with a #6 copper wire, I would check with local code to verify the wire size in your area. Make sure that the unit is grounded as well. Minimum of a #10 wire, I would also check local codes as well. Enjoy the steam!
Dec 27, 2010 | Steamist 11 KW Steam Unit SM11IM
Do I need to install a water softner before installing sm-79
you should not have to, but if the steamist is not gernerating the right amount of steam then you should put a sofftner on. you will be able to tell because it might have a hard time producing steam, but don't jump the gun right away.
Dec 09, 2010 | Steamist SM-79 7900
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
No steam output
Dec 06, 2009 - found solution: if unit is truely clean, unplug unit then mix about a teaspoon of iodized salt (table salt) to the water. Reconnect unit wait about 1 - 2 minutes, unit will start to make a grinding sound but shortly after steam will produce.
Nov 13, 2009 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Thermasol model 140 does not produce steam
call 1-800-776-0711 and get a EVA# to send unit in for repair.
Jan 10, 2009 | Thermasol Steamshower Generator AF Series...
Steamist Steam Bath 4.5/6 KW Unit SM46 Logo
78 people viewed this question
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
