Question about Toshiba 50HX81 50" Rear Projection Television
Blurry at first then when it warms up the distortion goes away
When I turn on my TV it is blurry across the screen, kinda freeky like then it will slowly clear up as it gets warmer it takes a while. Then it works. if I do not turn off the tv it s ok,
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Most of the Toshiba sets of this age had problems with a board inside that gives lines/noise left to right for several minutes and then clears up--as time goes on the warmup takes longer and longer---bad Hyper board with about 10 tiny surface mounted filter caps that dry out.
Part is not available and two options--either have a shop repair it or try it yourself---takes above average skill to remove board and replace all ten caps.
Shops will if they will attempt this usually get over 200 for the repair.
Posted on Oct 26, 2012
techman
  • 3130 Answers
SOURCE: Toshiba - 50H13 Projection TV
There is a large metal case behind the input board in the back of the set called the hyper board that needs to be replaced.Good Luck
Posted on Oct 08, 2007
SOURCE: lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Posted on Nov 28, 2007
djnick989
  • 1067 Answers
SOURCE: Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
tlm931
  • 273 Answers
SOURCE: my toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Posted on Jan 20, 2009
alicantecoli
  • 22156 Answers
SOURCE: tv takes a long time to warm up. after 20 min.
havent a clue normally only answer car questions,but if its one of them projection things then if its anything like the ones in our local bars then they have all chucked them and bought a flat screen with built in digital tv for the football on the spanish tv .Because they have all had similar problems to yours with them ,long time to work and fuzzy images and when you have a lot of scotsman and they cant see the ball you will understand why the english ended up with so many colonys ,Their violent
Posted on Nov 10, 2009
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
KD-34XBR970 CRT HDTV startup problem
This is a failure in the vertical amp section. One way to troubleshoot it is to get a can of freeze spray and use it on the suspect components. The other way is to inspect all the solder joints on the amp. Last would be to check voltages on the board. Since it does change with run time, it is being affected by heat.
Mar 12, 2017 | Televison & Video
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
THE PICTURES ARE BLURRY AND DISTORTED
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
Aug 21, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Insignia 32" TV Thin line across screen 1-2" from top
This is usually caused by bad capacitors in the vertical circuit. If you have an electronics background you should be able to find the defective ones with an ESR tester .
Dec 16, 2008 | Insignia NS- 27" TV27 TV
Blurry Line at Top of Screen
Unplugged the TV overnight and it seems to have gone back to normal.
Jun 25, 2008 | Panasonic PT-51G43 51 in. Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Sony 46 in. big screen picture problems
read this
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 10, 2008 | JVC AV-56WP74 56" Rear Projection...
Lines all across screen. Distorted picture
The it's surge protector is not an issue. Bring up the menu and see if the tv has the same problem. If it does not the problem is your small signal board. If it does and it is more than 1 line the panel could be the problem.
Aug 25, 2007 | Philips 42PF9630A 42 in. Plasma Television
Toshiba 50HX81 50" Rear Projection Television Logo
224 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
