Question about Hartke KM60 1x10 Keyboard Amplifier
Hartke km60 1x10 amp no sound coming out.
Power work.no sound come out?
  • arnel versola Oct 25, 2012
    when do i get my answer with my Hartke km60 1x10 amp
2 Suggested Answers
sg1972
  • 225 Answers
SOURCE: no sound coming out for my hartke amps?
Are the internal speakers properly connected via the rear-mounted 1/4 inch "Speaker Output" jack? If so and still no sound, try connecting a separate external speaker (floor monitor, pa cabinet) for a "low volume" test.
The OM says the internal speakers are 4 ohm so it's unlikely that a wiring problem with speaker connections would cause all four to stop working. With AC power disconnected from outlet check for an internal speaker protection fuse BUT be careful. Charged capacitors can hold a charge for weeks!!!
Posted on Nov 01, 2012
I need a schematic diagram with values of components for a hartke gt100 amp
Request the schematic diagram directly from Hartke.
May 23, 2017 | Hartke Music
Dropped Hartke amp b 600 and now it has no sound
There are too many possible problems for someone to advise you without the amp on the bench. I suggest taking it to an authorized Behringer repair as they will have better access to parts should it be a cracked board.
Jun 06, 2016 | Hartke Music
How can I repair np-11 wont sound
Hi, The reason for no sound could be many things.
Do you have power to the keyboard ( Red light, display lit up ? ) If not could be power supply or power input socket ( these fail and need repairing frequently on older models )
If you have power then check nothing stuck in headphone socket as this would stop sound.
If nothing stuck in headphones, does it work on headphones. If it does it is probably the amplifier that has stopped working.
If you can provide more specific I may be able to help further.
Dan
Oct 30, 2014 | Yamaha Music
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
Marshall Amplification Marshall MG2FX Guitar Combo Amp power turns on but no sound
Hi!
At this point, I would just take it to a tech rather than poke around in it. It sounds like the power section is the problem as you have guessed, but without the technical knowledge you'd be shooting in the dark. That particular amp is right on the line of being expensive enough that would be worth repairing, but you might do just as wel to check Ebay for another used one.
Good Luck!
May 21, 2014 | Marshall Amplification Marshall MG2FX...
No sound coming out of my mackie
Whether you are experienced in electronics repair?
if not, try this simply way:
1: Test whether the power amplifier is still working. See figure 1.
Power OFF,adjust the EQ settings as shown in the picture.
Minimize LEVEL.Switch ON Power. Touch pin 3 at the INPUT socket by using a small screwdriver or piece of wire / cable.
Slowly raise the LEVEL,a little bit only (as the clock showed 7-8) until
sound is heard in speaker. If not heard, slowly raise again LEVEL.
If audio input signal is heard,it can simply be taken to mean
that the amplifier is working.
If LEVEL at 9 o'clock position,and the audio is not heard,
the possibility of the amplifier is damaged.
Switch OFF the power. Take it to a repair place.
2: When the Power LED is lit, but no sound,
There are many possible causes, one of which is:
I have been getting 3 times similar cases, and all are caused by
two Rectifier-Diode (either or both.) damage on the power-supply-unit.
Remove/desolder,measure, if damaged replace it with a new one.
See figure 2-3.
Hope it helps. Regards.
May 13, 2014 | Mackie TH-15A Active DJ Powered THUMP...
Behringer ac 112 guitar amp powers up, display works. dials act normally, but no sound. only static as volume turned down (speaker works). amp was left on for long period
Try putting guitar trough the FX Loop, if there is still no sound, you may have a problem with the Power Supply.
Oct 01, 2013 | Music
Ha3500 hartke sound goes off with a click after 5 seconds .what is causing the problem
Sounds like the loudspeaker relay switch is disconnecting the spkr.
i) Check heat sensor on heatsink has good connection to PA board. Dust on h'sink/fan usually needs vacuuming off!
ii) Check voltage on the amplifier output resistor R334 is at 0v (referenced to chassis) - if this voltage is raised,the amp stage is faulty.
Otherwise the fault lies in the speaker protection stage (IC301).
Sep 24, 2013 | Hartke Ha2500 250watt Bass Amplifier Head
Hartke KM60 1x10 Keyboard Amplifier Logo
57 people viewed this question
Top Hartke Music Experts
Electro Med Services...
dave nyman
Level 1 Expert
Tom Chichester
Are you a Hartke Music Expert? Answer questions, earn points and help others
