Question about HP Photosmart C3180 All-In-One InkJet Printer
Cartridge alignment function repeats
Every time the power is turned on, the printer goes through the cartridge alignment function.  It prints out a new alignment sheet.  Previously, this only happened when I installed a new cartridge.
    Genius:
  • 2,120 Answers
You must replace both ink cartridges to get a sucessful alignment.
Posted on Jan 03, 2009
On an HP PSC 950, I'm getting a repeated "Press Enter to Align Cartridges" message when I try to copy. Got a response from a previous expert that wasn't even applicable to this model, and no response...
hello, the reason your printer is constantly trying to align cartridges, is it did not complete the alignment, machine must complete alignment, so this message will go away, this machine requires all #15 black ink cartridge and #78 color ink cartridge, it requires the color ink to be working since it uses either yellow or magenta ink for calibration,also black ink has to working for this to work. now if the ink cartridges are known good ink or printing ink cartridges, then the problem maybe the sensor that detects the color when it prints, you may try with a soft wet or damp paper towel, when cover is open as if you are replacing the inks, unplug printer from power, move carraige to left alittle bit more, on the right hand side of carraige, you might see a black piece of plastic, behind that is the sensor, use the wet towel and wipe the bottom part of carraige and sensor, do this several times. now go ahead and close machine and power up, see if machine will pickup paper, print the calibration page. if all is working it should pass.
Oct 06, 2010 | HP PSC 950 All-In-One InkJet Printer
A test page keeps on printing everytime the printer is switch on
The printer is printing alignment page. This will be printed if the printer was reset or if you have changed the ink cartridges. We need to complete the alignment process.
1. Place the printed page on the scanner correctly.
2. Press scan button on the printer.
3. The ON light will start blinking, wait until the ON/OFF light stops blinking.
4. Now the alignment is completed and it should not print anymore untill next cartridge change
Thank you
Rizwan.
Feb 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Hp 5150 only prints e-mail. When I try to print from Word, a sheet of paper goes into the printer, stops and then I get an message that the printer is out of paper. I have powered down many, many times,...
I had installed a new black print cartridge just before these problems happened. On this HP, when a new cartridge is installed, the printer must go through an alignment procedure and produce a printout in the process. For some reason I did not let the printer do this and that scrambled it's little electronic brains. The troubleshooting section of the printer's documentation recommends not only turning off the printer but unplugging it from its power source as well. Once that was done, the printer went through its alignment function, printed out the obligatory sheet and we were back to normal operations.
Lesson learned - when powering down, always unplug the printer as well as turning it off.
Nov 02, 2009 | HP DeskJet 5150 InkJet Printer
Printer prints test page every time i turn it on how do i stop this
It wants to align the cartridges so you have to have both color and black ink installed, and it needs all of the colors to do the alignment. Until it passes alignment it will keep printing that page.
Oct 29, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer keeps showing : Press enter to align cartridges. After doing this it then prints out an alignment page and shows: Alignment failed please: Press enter Alignment failed. This goes on and on. I have...
I have found that if I put in an old aligned page the printer reads it as and the alignment is accepted. As for the cancelled message being in the window, I have had this problem too. I've ignored it and selected the copy button and it took the command. The only problem with hitting cancel is that you cannot turn off your printer. Every time you do you have to repeat the aligning and cancellation process.
May 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
140 people viewed this question
Ben Johnson
