Question about Dryers
Problem replacing drive belt of a GE DHDSR46EE1WW dryer
I'm trying to replace the belt of my GE DHDSR46EE1WW drier. I took the old broken belt to my local appliance parts store and they said that particular model (WE12M22) of belt is not sold anymore and they sold me a replacement (WE12M29). I took the dryer apart and tried to put the belt on, passed it around the motor drive and the pulley but there's a really big slack. At first I though this replacement was wrong so I called them and they confirmed it is the right one. I measured the belts and they are the same size. So I guess I must be doing something wrong. I need a to know exactly how to install this belt around the motor drive and pulley so there won't be this big slack. Can anybody help me here?
  • 115 Answers
Bosch Exxcel Condenser
replace the broken drive belt
May 13, 2013 | Dryers
Amana LE7153WM drier will not start... makes a low humming sound when you push in the select dial to start the drier
Hi John, W/D here.
Most likely scenario: squealing was either a belt or a bearing. Failure to run is probably a broken belt. Gain access to the back of the drier, with the power disconnected. Open the back and check the belt. If broken, replace it, and then rotate the drier by hand, listening for additional squeals and squeaks. If no other issues are noted, replace the back cover, plug it back in and try it out.
Best regards, --W/D--
Nov 09, 2011 | Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
I have an old GE dryer model DDG5380valwh. When try to start it it just hums. What should I do?
** ALLWAYS unplug a dryer before working on it.
Humming means the motor may not be turning.
The motor could be 'capacitor start'. Replace the capacitor.
The motor could be centrifugal start. Remove the belt. Still won't start? Replace the motor.
The motor bearings could be seized. Rebuild the motor or replace it.
The belt may be broken if the humming is a higher pitch. Replace the belt.
The drum may be jammed. Clean and lube the main bearing (Use Maytag Turbine oil or the recommended lube), the support wheels or the guides. Replace felt seals at the same time for best results.
Mar 22, 2010 | GE DWSR405EBWW Electric Dryer
Ge dryer is heating up but drum is not turning
I believe the motor needs to be replaced.
If the appliance still under warranty, contact the manufacturer for assistance.
Sep 01, 2009 | General Electric Dryers
Old GE drier - Is it gas dryer or electric
it's a gas and you need a new gas or a 220 volt dryer.
Jun 24, 2009 | GE DCSR483EA Electric Dryer
Ge dryer model #DHDSR46EE1WW. Dryer will not run- just makes loud humming noise. Replaced the start switch and it still will not run at all. PLEASE HELP!
You most likely have a bad motor. Try to spin the dryer drum by hand with the door open, door swich held or taped down, and while pressing start. This will likely get the motor going. If this works try closing the door and starting it again. If it works now the motor may have just had a hard time starting do to it's position or the drum's postition. If it only works when you help it out manually you have a bad motor or maybe a sticky drum/jammed belt/etc. Good luck!
Apr 28, 2009 | General Electric DHDSR46EGWW Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
GE Dryer DVL 223GB1WW
ALWAYS UNPLUG ANY APPLIANCE AND TURN OFF THE GAS VAVE BEHIND THE DRIER BEFORE ATTEMTING TO MOVE IT. I HAVE REPAIRED GAS FIRED EQUIPMENT FOR YEARS ...ALWAYS MAKE SURE YOU LOCATE YOUR GAS METER IN THE HOUSE OR OUTSIDE AND HAVE A ADJUSTABLE WRENCH READY. I HAD A GAS VALVE BREAK-OFF IN MY HAND AND, A FLEX-LINE BREAK WHEN I MOVED A DRIER ... I WAS LUCKY I KNEW WHERE THE METER WAS. YOU CANT BE TOO SAFE !!! THE ONLY WAY TO CHECK A BELT IS TO REMOVE IT ... THERE IS A SEPERATE ADJUSTABLE PULLEY THAT ADJUST THE BELT TENSION (USUALLY LOCATED AT THE BOTTOM OF DRIER BELOW THE DRUM NEAR THE DRIVE MOTOR) YOU MAY OR MAY NOT HAVE TO LOOSEN THIS ADJUSTABLE PULLEY TO REMOVE THE BELT. FIND A CLEAR AREA WHERE THE BELT IS NOT ON THE SRUM AND PRESS ON THE BELT ... THERE SHOULD BE NO MORE THAN 1/2" OF "PLAY" ( MOVEMENT)IN THE BELT AFTER YOU REMOVE THE BELT ... TURN IT IN-SIDE OUT. AND SLOWLY ROTATE IT ... INSPECTING EVERY INCH FOR CRACKS AND EVSERSIVE SIDE WEAR. IF THERE ARE ANY CRACKS, VISABLE PLYS (LAYERS) OF THE BELT CAN BE SEEN, OR IT IS REAL SHINNY ON THE SIDES... THE BELT SHOULD BE REPLACED. WHILE THE BELT IS OFF ... USE YUR HAND AND SPIN THE DRUM TO CHECK FOR ANY WOBBLE.... THERE SHOULD BE NO WOBLING ... IF THERE IS IT MAY INDICATE BAD BEARINGS... HOPE THIS HELPED
Apr 28, 2007 | GE DVL223GB Gas Dryer
Dryers Logo
744 people viewed this question
Top Dryers Experts
