Question about Mitsubishi WD-52825 52" Rear Projection HDTV
I did all the checklists per manual and it still doesn't work, what next.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
What is set doing or not doing?
Posted on Oct 26, 2012
Rmp gage is not automatically shifting into next gear its just increasing to 3 & 4K RPM what could cause this?
it sounds like it is in safe mode it will start in 2 nd when it dose
you need to have it scaned
Jun 03, 2013 | 1998 Chevrolet Blazer
Pa
per fcc rules (laws)? you cannot put an amp on a cb. max output 4 amps. you should be able to put a pa speaker using the pa output jack. take your radio back for warranty.
May 19, 2013 | Cobra 19 DX IV CB Radio
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
I can't depend on it working, sometimes it is great other times it doesn't light.
Intermittent operation is usually a "Flow" problem. Water needs to circulate at a certain amount of water per minute. Most problems are due to restriction of water flow.
Most common problem = Dirty Filter
Backwash on a regular basis for starters.
If a sand filter, sand needs to be replaced on average every 7 years.If a DE filter, then you may need to completely break down your filter and manually remove & clean the grids. Then at reassembly, add the proper amount of DE back into filter by introducing via the skimmer.If a Cartridge filter, then complete break down and manually cleansing the elements. Possibly replacing them if they are older than 4 years old.
Dec 17, 2012 | Pentair Minimax NT Heater
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
I have a 2003 ford escape & the digital odometer doesn't work correctly
Have the dealer do a speedometer accuracy test. They have a special tool that can electronically read the speed and then compare it to the readout of the odometer.
Jul 16, 2012 | 2003 Ford Escape
12,000 btu emerson quiet kool 220/230 about 9 years old, need to know $$ per hour to run with total kw/h cost $0.30 (this includes all taxes and fees). Sorry can't provide wattage or amps (no manual...
If your device doesn't list wattage, but it does list amps, then just multiply the amps times the voltage to get the watts. For example:
amps x volts = watts x .30 if you dont have any information you are sol.
Jul 06, 2011 | Emerson Quiet Kool 10NW16K Air Conditioner
My laptop has had a complete memory boot and i can not get my wireless connection back on. How do i correct this problem/ i am using a ethernet cable at the moment to get connection to internet. Thank you
Improve the Fixya.com experience for everyone by voting!
The first solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Make sure your service provider has activated your account and services on the subscribed line. Please check with your service provider to confirm this.
? Make sure that you are using the latest drivers. You can download the latest driver from Driver Downloads Database.
? Make sure that you have entered the right username and password (case-sensitive) as given by your service provider. For example, in Australia: user@bigpond; in NZ: user.name.xadsl@xtra.co.nz.
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online. However, if it doesn't get you on line, do the following: Click on tools again. Click on 'Diagnose Connection Problems' and follow the instructions.
The last choice is to use the Setup Wizard. It seldom works for me but you might more luck than poor me. Here are the instructions:
The Connect to the Internet wizard will guide you through the steps of setting up an Internet connection.
Open the Connect to the Internet wizard by:
• Clicking the Start button Picture of the Start button
• Click on Control Panel.
• In the search box, type network,
• Click "Network and Sharing Center"
• Click Set up a new connection or network
• Then double-click "Connect to the Internet".
All the best
Ben
Jun 18, 2011 | Acer Aspire 5315 Notebook
I have a netgear wnce2001 universal internet adapter. It was previously configured to the wireless internet in home to work with Xbox. Just yesterday the WLAN line went out. Hooked ethernet and USB cable...
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
? Click on 'Tools';
? Click on 'Setup'
? Click on 'Next';
? Clock on 'Next'
? Click on 'No';
? Click on 'Next';
All the best
Ben
Jun 18, 2011 | Computers & Internet
It's getting gas, the battery's good, the fuel pump is working, & I just replaced the rotor, cap, plugs & wires. Every few weeks or so though, she just doesn't start. The only...
At first blush, it sounds like the distributor cap isn't seated. Since it's happening when the engine is cold and at night, I'm guessing condensation is causing the problem. Try spraying starter fluid on the cap the next time the car doesn't start. This will dispel any condensation. If the car starts, that would be a good place to start.
Jun 05, 2011 | Volkswagen Fox Cars & Trucks
Open Questions:
Mitsubishi WD-52825 52" Rear Projection HDTV Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
