Question about Westward 1YMN2 Jump Starter Booster/Air Compressor
I'm looking for the directions booklet for westward 1ymn2 jump starter booster/air compressor
Need operating booklet for westward 1ymn2 jump starter booster/air compressor
AC adapter requirements
Grainger sells the unit as well as replacement chargers. They should be able to direct you to which one you need (there are 2 available)
Mar 02, 2014 | Westward 3LE85 - Portable Power Source,...
Where to find adapter
stores that sell the brand and model may have the available adapter but I doubt it if they sell them as separate parts for they all come from the manufacturer as a set. or else you may order directly from the manufacturer for the adapter.
Dec 28, 2013 | RoadPro Road Pro 12 Volt Dc Portable...
Air compressor
isn't one but the owners manual might have some simple trouble shooting info in the back
Nov 13, 2013 | Westward Air Tools & Compressors
Suzuki VL125 starter motor won't turn, ignition on, cutout in correct position, neutral light showing, hold clutch lever in, on operating starter switch I just hear a click from under the seat. If
Locate the solenoid (the thing that clicks) and peel back the rubber boots from the terminals, put a large screwdriver or metal rod between the terminals. If you get sparks and the starter turns the solenoid is faulty. If you get sparks but no starter then check the wire down to the starter and make sure it hasn't been worn through and is shorting out. If that is ok do a final check bu jumping directly to starter ie positive to starter and negative to frame. If the starter still fails to turn it need replacing
Jun 25, 2012 | Suzuki Motorcycles
I have a Duralast Gold Jump Starter.I charged the battery green light is on but when I try to start a car engine it looks like the jump starter does not have enough power to do the job. Note.- I acquire...
I had the same problem today and I found out that is the battery itself causing the problem. It's actually the connection. So disconnect the battery and scratch the battery pins and connect them again. If you can dip them in soda water (no sugar in it!) that would be better.
This problem starts as the battery beggins to get old and combined with cold weather outside becaomes a receipe for disaster. Anyway, if you can't afford a new battery at the moment remove your battery from your car (but first try and drain it totally...leave a light on or something) and recharge it (fully) with the duralast (havbe the duralst plugget into a outlet). It will have your battery working for couple of weeks.
Dec 03, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Need a charger to charge my Jump Starter BP-DLG
Need confirmation that the AC adaptor for Duralast jump start model BP-DLG is a 12volt 450ma. Is this correct or do I need something else?
Nov 06, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Where can i get a manual?(duralast jump starter)
They don't have a web downloaded manual.
Phone:
Toll Free (866) 622-7979
(Monday-Friday — 8:30 am - 5:00 pm e.s.t) Mail: RoadPro
1875 Zeager Road
Elizabethtown, PA 17022 E-Mail: support@das-roadpro.com
Nov 28, 2009 | RoadPro Road Pro 12 Volt Dc Portable...
Westward 1YMN2 Jump Starter Booster/Air Compressor Logo
128 people viewed this question
Top Westward Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Westward Air Tool and Compressor Expert? Answer questions, earn points and help others
