Question about Compaq Presario Computers & Internet
I can delete from add/remove prgms ok , if I delete 2008 to 2011 will it affect my computer old files
If I delete old programs from 2008-11 from add/remove programs will it effect my computer. Have windows xp
  • elmundo350
    elmundo350 Oct 25, 2012
    good I have a destop computer and have the latest updates on this thank you
It really depends on the program you want to remove. If it is something you don't use anymore, then it will be just fine to remove. Be careful not to remove your anti-virus or software that contains drivers ie. display driver software
Posted on Oct 25, 2012
eagle338
  • 4889 Answers
SOURCE: Uninstallation Problem
Well if you want to delete click start->run->type "msconfig" In the configuration window click on services tab. Uncheck all the entries named symantec or norton. Now click on STARTUP tab and uncheck the symatec startup entries. Now restart the computer and try deleting once again. By the way that access denied message is displayed because the file u want to delete is being used by some symantec service if unselect and restart they will be terminated so that you ca delete the folder.
Posted on Oct 08, 2007
bsrjth
  • 270 Answers
SOURCE: error code 0x80040702
it may not be removed compltely . use any mamory defragmention progrmas like ram booster ot dspeet it up extreme and defragameny ur ram and try insatalling again
Posted on Dec 22, 2007
SOURCE: Unable to delete a video file
http://ccollomb.free.fr/unlocker/
Use This
Posted on Jan 04, 2009
  • 258 Answers
SOURCE: Files have removed not deleted to a unknown location
There is no reason why this should happen when removing a program or software.
Have you tried a system restore?
It doesn't normally retrieve missing files but as it is files specifically related to a program it may work.
Backup everything you want first, e.g copy my documents etc to an external drive
Start --> All programs --> Accessories --> System Tools --> System Restore
Click Restore my computer to an earlier date
Select a date in bold before the date when you removed the software
Click Next , next
Leave the pc to restore, power plugged in
You can always undo this restore later
If problems, please post results and I will help
Error messages etc.
Thanks
Posted on Jan 17, 2009
taran_2005
  • 10515 Answers
SOURCE: cant delete yahoo messange from my computer
c:\program files\yahoo messenger, --- look for the folder yahoo messenger.
delete the folder.
right click start button. - click explore. goto programs. if yahoo messenger is listed delete it.
Now yahoo messenger SHOULD not load up on startup and be an phantom on your hard disk.
Please Note: If all fails, boot in SAFE MODE. then do this process. As well, your computer could be having yahoo loaded as an process making the file in use, thus being locked.
google on how to get into safe mode if you dont know how. I usually shutdown the computer a couple of times improperly or press an certain keystroke.
Hope this helps...
Posted on Jan 30, 2009
Where do I find help for a code 18 error MTP Driver
Ok, here's the solution.
My computer is running on Xp-SP3.
Go to "Add or Remove Programs",
then Un-Install all the Nokia Stuff - all of it,
select the Windows Media Player and click "Remove" -
Don't worry!!!!
Windows Media player won't be deleted, just downgraded to a previous version,
stay within the "Add or Remove Programs" list
Select "Windows Media Format 11 runtime" and click "Remove",
confirm and then restart your PC.
Download the OVI-Suite from the Web Page (do not use the CD) and install OVI-Suite.
Install also the OVI-Player from the Web Page.
Restart PC.
Open OVI-Player, connect your phone and try to move a mp3 file directly into the phone's directory - then update your phone's music library
Feb 18, 2015 | Computers & Internet
Tip
How to assign a permanent drive letter for removable drives
1. Go to Start > Run
2. Type mmc in the box and hit enter.
3. Select File > New
4. Now select File > Add/Remove Snap-in.
5. Select “Disk Management” and click “Add
6. Select “OK“.
7. Select “This computer” and then “Finish
8. Now press “OK” on the “Add or Remove snap-ins” screen.
9. Now select “Disk Management” from the left menu.
10.You will now see all of your drives/partitions in the right hand side panel.
11.Right click the USB drive you want to assign a permanent letter to and select “Change Drive Letter and Paths…
12. Click on “Change
13. Select a permanent letter
14. Click “OK
15. It will warn you about making the change – there is little chance programs you use will be affected by this. If they will, you will probably already be aware of this so don’t worry.
16. The final step is to select File > Save and save the file in the default directory. Close the Console and you are done.
Now eject your usb drive and put it back in and see whether it is showing the assigned letter or not.
Please Vote for this Tip if you found it helpful….
on May 17, 2010 | Computers & Internet
Remove snap do
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Jan 30, 2013 | HP Computers & Internet
How do I delete Weatherblink from my computer? I tried add/remove programs but even though it is listed add/remove says they cannot find the program.
If you perform a search via the start menu for the files associated with this program, any files renaming will show up there. You can delete each file when they come up and this should fully remove the program.
Aug 04, 2011 | weatherblink.com
I unistalled the yahoo messenger after that i deleted the files from programs files...and nothing....i scaned the hole system for any virus with 3 antivirus and i dont have any virus..what i do now?
Note : Program will note deleted by using ' uninstall/removing ' program from control panel only . Also ,
removing this program may affect your computer performance
If you still wish to remove this program permanently, follow below steps :
After removing its program ,
You must go to Registry editor menu.
From Start menu ? Run?type regedit.exe ?Ok.
This will make registry editor to open.
Then go to registry entry HKEY_CURRENT_USER\ Software\, delete Yahoo.
Jay, The FixYa
Dec 04, 2010 | Yahoo Messenger
Hard drive is full need more space
From Control Panel go to Add/Remove Programs
Remove programs that no longer useful to you and delete documents, pictures any file that you don't need anymore.
if you don't have nothing to do with removing programs and deleting files, you have to upgrade or add a secondary hard drive, or a external drive will be a helpful to you, move all your files to your external drive this will also counted as your backup files.
Jan 05, 2010 | ASUS (90N804SH021) Hard Drive
Delete from add delete at control panel
The only way to modify the add/remove programs list is to edit the registry. If you are uncomfortable doing this, get someone to help who is, or just leave the registry alone.
It's best to back up the registry in case you make a mistake.
To back up your registry, see this article.
On to the fun part. Follow these instructions exactly. Note: this applies to Windows XP only. If you have Windows Vista, please modify the question.
  1. Click Start, and then click Run.
  2. In the Open box, type regedt32, and then click OK.
  3. In Registry Editor, locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall
  4. In the left pane, click the Uninstall registry key, and then click Export on the File menu.
  5. In the Export Registry File dialog box that appears, click Desktop in the Save in list, type uninstall in the File name box, and then click Save.
  6. Each key listed under Uninstall in the left pane of Registry Editor represents a program that is displayed in the Currently installed programs list of the Add or Remove Programs tool. To determine which program that each key represents, click the key, and then view the following values in the details pane on the right: DisplayName: The value data for the DisplayName key is the name that is listed in Add or Remove Programs.
    -and-
    UninstallString: The value data for the UninstallString key is the program that is used to uninstall the program.
  7. After you identify the registry key that represents the program that you removed but which is still displayed in the Currently installed programs list of Add or Remove Programs, right-click the key in the left pane of the Registry Editor window, and then click Delete.
    Click Yes in response to the "Are you sure you want to delete this key and all of its subkeys?" message.
  8. On the File menu, click Exit to quit Registry Editor.
  9. Click Start, click Control Panel, and then click Add or Remove Programs.
    In the Currently installed programs list, verify that the program whose registry key you deleted is no longer listed.
  10. Do one of the following:
    • If the program list is not correct in Add or Remove Programs, double-click the Uninstall.reg file that you saved to your desktop in step 5 to restore the original list of programs in the registry.
      -or-
    • If the program list is correct in Add or Remove Programs, right-click the Uninstall.reg file on your desktop, and then click Delete.
Mar 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Local disk space problem
delete or add remove program that are installed on ur c: & when u reinstall them mention the path as e:..................this will help u.........................Sameeraryan
Jan 15, 2009 | Compaq Evo D300 PC Desktop
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Remving songs from Ilo MP3 player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Oct 28, 2007 | iLO (2 GB) MP3 Player
Computers & Internet Logo
74 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
