Question about Denon AVR-2307 Receiver
Denon AVR-2307 Protection Circuit Activated permenantly
I have a Denon AVR-2307 surround receiver with Mirage Omnisat V2 Series floorstanding front speakers and the Omnisat V2 Centre speaker plus Niles HD6 in wall surround speakers.
Now for the second time the receiver has gone into protection circuit mode. The first time the resistors and diodes were replaced in front left and centre output stages under warranty.
Now that this has happened a second time I have been investigating and wonder whether I have an impedance mismatch issue with the receiver and the speakers.
The receiver is rated front A,B at 100w + 100w (8 ohms, 20hz -20 khz), centre 100w (8 homs, 20hz - 20khz), surround is the same.
According to the manual, the impedance on all the speakers is 6 - 16 ohms.
The Mirage front speakers are rated at 175 watts and their impedance is 8-ohm nominal and 4 ohm min. The centre speaker is the same. The Niles surround speakers are rated at 10 to 125 watts per channel and their Nominal Impedance is 6 ohms.
Both times when this has occurred it has been whilst playing music DVD's at high volume, but not extreme. So, I am wondering if the amp has had to be pushing too much power over the period and it has clipped and damaged the circuitry? Can you advise if this is possibly the case.
The system was sold to me by an authorised Denon dealer in Adelaide South Australia and if there is a mismatch I am wondering if I have any comeback on them?
Thanks,
The speakers are 4 ohm speakers, a guy on another chat site sent me a link to the impedance curves http://www.audioholics.com/reviews/s...t-v2-fs/page-4
He agreed to that there was a mismatch as the unit has plenty of fresh air around it, plus all the speaker cables have been tested and installed correctly.
So, off to the store where I got it from tomorrow.
Posted on Jan 04, 2009
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Display on Denon AVR-2307 won't work
It may seem obvious, but have you checked the display dimmer settings? Under the front cover is a button marked dimmer. Pressing it cycles through progressive display dimness settings until it goes off. One more press goes back to full brightness.
Dec 30, 2008 | Denon AVR-2807 Receiver
DENON 2308
IF YOU HAVE A MANUAL FOR YOUR DENON THE INSTRUCTIONS FOR ADJUSTING THE BASS AND TREBLE IS ON PAGE 40 UNDER TONE CONTROL IF NO MANUAL FOLLOW THIS LINK TO DENONS WEBSITE http://www.usa.denon.com/AVR-2308CI-OM-E_109.pdf
Nov 26, 2008 | Denon AVR-2307 Receiver
Denon AVR3300 - Resetting activated Protection Circuit
Hi
Remove all speakers cables or wires and check all from behind the Receiver. if there are any loose terminals or any metal object in between the terminals.
though it might be a coincidence that you have a problem in the Receiver.
unplug the power cable from the wall socket and remove all cables.
after you remove the cables plug the power cable in the wall socket and try if you see the protection displayed , the receiver needs service.
Good Luck
Regards
Nov 02, 2017 | Denon AVR-3300 Receiver
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
Mar 26, 2008 | Denon AVR-883 Receiver
Denon AVR-2307 Receiver Logo
728 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
