Question about Infinity BU-2 Speaker
Bu2 subwoof hookup / infinity surround sound setup
I have 4 bookshelf infinity speakers & 1center shelf speaker ('minuettes'), 2 old skool box floor speakers, and i bu2 woof. i have no manual and wish to setup for music and movies. music = alt/punk, blues/bluesrock, reggae. very rarely hip-hop. movies = crime drama, comedies, mostly music dvds.
running thru onkyo HD a/v contol receiver TX-SV545 with 6disc changer DX-c340.
space = 12ft length and 11 ft deep with a/v units on length wall, seating on opposite length wall. plan on subwoof behind dual recliner couch on floor at an open space where walls meet at 90 degrees.
used system from buddy, i wish to maximize surruond capabilities and HAVE NO MANUAL! OR REMOTE!
3 Suggested Answers
fkuk
  • 311 Answers
SOURCE: Can I replace the sub woofer in my home stereo
if the impedance of the new speaker matches the impedance of the old one then i dont see why it wont work
Posted on Jan 01, 2010
Grubhead
  • 5309 Answers
SOURCE: No sound coming from my Infinity BU2 subwoofer.
I suspect that whatever semiconductor does all the amplifaction has departed this life. If you check the PC board it might point to a burnt out part or a blown one. If not look at anything big or with a heatsink on it.
Posted on Feb 02, 2010
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Sep 07, 2010 | JBL PSW-D110 Speaker
I have a four channel rockfor fosgate amp and I need to know hows the best way to connect Infinity Reference 1252w Car Subwoofers
Rockford fosgate usually work best with 2 ohm speakers. Depending on the resistance of your speakers, will then give you best connection. Check the resistance for the subwoofers. If the subwoofers are two ohm then connect them directly right and left. But if they are 4 ohm connect them parrallel (positive to postive, negative to negative and bridge the amp.) Good Luck, please rate.
May 26, 2010 | Infinity Reference 1252W Subwoofer - 12"...
How do i get the best sound from my infinity 1250w subwoofers
Make sure the ohm's are the same on all your speakers and amp.
You amp watt should be equal or higher then your speakers total amps.
You base box should be completely air tight, and have about 1/2 of the box stuffed with cotton.
Make sure you use a good thick speaker cables to connect from the amp to the speakers.
and finally, make sure your trunk seals tight and wont rattle... cause nothing sounds worse then someone pulling next to you and all you hear is a buzzing sound from the trunk rattling... Also... sell the infinity's and get something like memphis, or panasonics. :P
Mar 09, 2010 | Infinity 1250w Car Subwoofer
No sound coming from my Infinity BU2 subwoofer. Powers up, light comes on, relay clicks, and nothing.
Feb 01, 2010 | Infinity BU-2 Speaker
Speaker not working
Either. You can probably order a new driver (speaker, no box) from Mission, then put it in yourself. This usually involves 4 screws around the speaker, then disconnecting a coulple of wires, putting the new one in and letting the speaker bed in for a while. You've then got a working speaker, and a nice paperweight.
If you have more money, and fancy an upgrade, you can buy some new speakers. An odd one wouldn't match the others, so it would be 4 satellites and a centre required. The subwoofer should be fine.
Jan 08, 2010 | Theater Research TR-502 5.1 Surround Sound...
Speakers won't play ''loud at all '' Just Very faint
they dont sound loud because you need to use the DUAL voice coils and make it 2 Ohms. Google " how to bridge a dual voice coil sub"
May 25, 2009 | Infinity Reference 1052W Subwoofer - 10"...
Have a BU2 subwoofer no sound
start by checking for a blown fuse. Sometimes the fuse holder is on the back panel.
Feb 09, 2008 | Infinity BU-120 Subwoofer
265 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
