Question about RTO 110cc Basic Manual ATV # ATD-125C
Ares 110cc four wheeler won't start gas not getting to carb
Was running before i try to clean carb and fix the float because gas kept on running out of the overflow line put everything back together and now won't start please help someone
    Problem Solver:
  • 5 Answers
Chk your tank and lines for trash blockage, when you get fuel to the carb go from there, the overflowing is caused by the needle valve in the carb sticking open, usually caused by trash in the fuel, make sure you are getting fire to the plug as well, I know for a fact the wiring systems on these things are not quality systems.
Posted on Oct 25, 2012
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
How do i re-jet my carburetors on a 2007 suzuki LT-A 400F four wheeler?
when engines not running turn the gas off . And it sounds like you need to adjust your throttle pin that goes into the carb take the clip off the pin and move it down one good luck
Nov 23, 2012 | RTO 125cc ATV Quads Full Size Adult four...
My three wheeler doesn't stay running when it starts. What could be the problem besides the fuel line . just added a fuel filter on it but she still won't start or stay running at times. Co
The damage is already done before you put the fuel filter in. (dirt in Carb)
Remove your carb and dissesemble it and clean everything out and then put back on the machine with FRESH gas and you will be fine...run like a top !
Jul 06, 2012 | Cars & Trucks
Lower carburetor flexible gas outline is draining and i don;t know how to fixed
sounds like your carb float is stuck and your needle and seat is open allowing the bowl to fill with gas and run out the overflow. take off the bottom bowl of carb and check to see if the float has a hole in it.
Apr 26, 2010 | RTO 200cc Full Size Four Wheeler ATV
Gas leaking from bottom of carb on 90cc ATV
yes there is a tube that goes on it. It hangs straight down about an inch or two past the botom of the 4 wheelers frame. It is for a overflow of gas, which is usally caused by either dirt in the carb holding the float to high and allowing the gas to just run straight thru and out the bottom of the carb or a bent or maladjusted float setting. But since you said it just started, i would suggest this. I have fixed many and many bikes by simply removing the carb bottom and cleaning it with carb cleaner. It onlty takes a small piece of dirt between the float needle to keep the needle from making a good seat in the carb. Clean it well Please be carefull and keep the carb well away from your face as to not get any blowback of cleaner in your eyes(IT BURNS) This should fix your probblem
Let me know
May 31, 2009 | 2005 Yamaha TT-R 125 L
110cc pocket bike carberator
That tube would be the overflow tube. Your carb float is sticking open and allowing fuel to flow in constantly. You need to take carb apart, clean needle valve, and inspect or replace carb float.
Apr 21, 2009 | Pit SSR 110CC Pro Beginner Bike
RTO 110cc Basic Manual ATV  # ATD-125C Logo
328 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
